Originally posted by reeftool It's in the section labeled Manufacturers Notes.
Since it's below 0 outside and I had no desire to get out and do anything, I spent a good while looking through my photos and reading the exif in PhotoME. My K5 regularly listed the SR Focal length as 45mm when I shot at 17mm. I began checking some other focal lengths and found similar results. There were also slightly off SR results at longer lengths but only by a couple of mm's and not enough to likely cause a problem. I also found some differences in other lenses too, but only by a very little. Then another problem surfaced. I went back and looked at some of the other data in those 17mm shots I checked earlier and they are now listing the SR length as 52mm!
Since these are all pretty sharp photos, I'm beginning to think this is a problem with PhotoME. Why would the data change? I also found instances where my DA 10-17 was listed as an "M" or "K" lens even though in other places in the data it is correctly listed as a DA. I think PhotoME isn't correctly reading the data. My AV software also has tried to block PhotoME as malware.
Rather than send a lens back, the real answer to all this is to follow the rules of photography and use a tripod if you want to shoot at slow shutter speeds. It's always a crap shoot under 1/30 and for longer lenses, the minimum is usually the focal length; don't try to shoot with a 200mm under 1/200, etc and even that is no guarantee.
I'm pretty confident this is no PhotoMe problem, and it's always possible to cross-check with other software. Of course all this will be a non-issue if you shoot at 1/100 or 1/50 seconds (or with flash), as these speeds are fast enough even with screwed-up SR. But try getting decent shots at 1/10 seconds with the Sigma @17 and e.g. a DA 18-55 or 18-135 @18 if you have one. With the Pentax lenses (which show the correct 18 or 19mm as SR focal length) this is no big deal, with the Sigma it's nearly impossible. As written above, it's actually easier with SR
off.
---------- Post added 07-01-15 at 19:28 ----------
Originally posted by Rupert What is the difference between this an my older 17-70? I took a few test shots at 17mm 1/15 in my dim office and they looked plenty good....my K5 original is not the best at low light shooting at slow speeds, but they appeared decent using the Sigma SR.
Regards!
The 17-70 Contemporary is a completely new construction and lacks the in-lens stabilisation. Your lens is a previous version and most likely may not be affected at all, especially when you use the in-lens stabilizer, so no worries
