Originally posted by sTi It's difficult to say where the problem originates without having inside knowledge of the K-mount communication protocols - maybe the Sigma lens sends incomplete or wrong data to the camera, maybe the camera misinterprets something because it does not fully recognize the lens ID, or maybe something completely different is the problem. However, I'm pretty certain Pentax will feel no responsibility to do anything about it because SR works perfectly with original Pentax lenses. Our only chance is Sigma doing something about it (if it's even technically possible) I'm afraid...
I have two other Sigma lenses that do not display this issue. My 70-200mm HSM II (a bit older, I think around 2009 or 2010) is always within a couple mm of the reported focal length. That makes sense that the two not be 100% identical because if they always are, then why both having two separate parameters?
I checked about 10 of my images with the Sigma 18-35 f/1.8. Those were 100% identical. Now, this is a lens that has been reported to have major focus issues (which I have not seen to nearly the extent of what others have), which are most assuredly something miscommunicating between the lens and body.
If the issue is in the lens, it seems to be unique to the 17-70. I never noticed the issue because I avoided those low shutter speeds. Come to think of it, I think I did so because the pictures didn't come out so well. I had always assumed that 1/10 is just too slow, even with shake reduction. But I am able to hold the 18-35 at the wide end at that shutter speed and have even gone down as low as 1/6 with limited success. (Anything slower....forget it.)
