Originally posted by richandfleur If one purchases a Contemporary version of this lens for Pentax, will it work with a K-3 SR or does it require a dock fix etc?
There were two issues addressed in the firmware update. One was a problem with AF and the other with the lens not reporting the proper focal length to the body. One can easily check to see if the second issue is a problem by monitoring the
displayed FL in the EXIF or detailed review screen as compared to the position on the lens barrel. The value used by the SR system is not particularly sensitive as long as the FL is reasonably close.
FWIW, I have been shooting with the "C" version on the K-3 since Spring of 2014 with its original firmware and have not had any problem with SR at the wide end. I would expect that current production "C" version lenses will have the proper firmware version flashed, though that is difficult to assess without a dock. Perhaps a note to Sigma might provide the answer?
