05-28-2008, 07:07 AM   #46
reeftool's Avatar
QuoteOriginally posted by Entropy Quote
Same will likely go for camera sensors. Yes, usually technology progression leads to things becoming smaller, EXCEPT where large size is desirable, such as in TVs and high-quality camera sensors. Yes, APS-C noise performance will consistently improve (at least for a while), but most of those improvements can also be applied to FF sensors, along with improved manufacturing techniques that make the sensors cheaper.
Comparing the size of a tv screen isn't quite the same thing as a camera sensor. A 20 in. screen viewed across a room will always be 20 inches. Image quality from sensors is constantly improving and it won't be long before little point and shoot sized cameras will have IQ that rivals our current DSLR's. Full frame sensors remind me of pickup trucks. Contractors and farmers need the large full sized trucks to do their work. 90% of the people who drive them don't and they are finding that out the hard way these days every time they get gas. There will always be a full frame camera for the pro's and studio's just like the big view cameras never disappeared for film but I don't think any of us has to worry about our DA lenses becoming obsolete in the near future.
05-28-2008, 07:19 AM   #47
chadvw's Avatar
QuoteOriginally posted by Zewrak Quote
Well, then you really don't need a fullformat either . I can't see a downside to why not have for example 14mpixel when the technology is there, as long as it doesnt come at the expense of something else, noise for example.
The more data you have the better imho.
full frame and megapixel size aren't the same. 10mp on an aps sensor or 10mp on a full frame sensor....
but I'm not going to make this into a MP debate, already turned the original topic around enough.
05-28-2008, 07:05 PM   #48
ManuH's Avatar
It’s funny to see all these FF debates and how some people try to see through a Crystal Ball.
I think there will be more FF cameras in the future, even from Pentax.
First fact: all mounts are still the same as they were during the 35mm era. They can all (except for Olympus which is already FF by definition) accept a FF sensor without any change of the mount. Therefore it’s an obvious evolution and an easy answer for the camera maker to the ever growing megapixel race.
Second, don’t worry about buying DA or FA lenses. Your old FA lenses worked on APS-C and your new DA lenses will also work on a FF body, you will just have to crop the image just like the way Nikon is doing it automatically on the D3. You can use a FF camera as an APS-C camera. So if you prefer APS-C just push the APS-C button and voilà. And a 15MP crop from a 30MP FF will still be of very high quality unless you want to print very big.
Third, let’s not try to foresee too much the future, buy what you need *now*, not what you *may* need later. I’ve got burned too many times not following this simple advice in other technologic sectors. You can never predict what new technology can change everything.
In conclusion don’t worry too much about FF, when it will come, it will not make all your lenses obsoletes. I’ll buy one if the price is right, if not, I’ll stick with an APS-C which already have much more image quality than most of us really need.
My 2 cents
01-28-2011, 11:43 AM   #49
valarie's Avatar
QuoteOriginally posted by Gooshin Quote
what is FULL FRAME??!!?!!?
you guys are mind boggling
everyone is hell bent on adhering to an arbitrary standard set decades ago
for what?
what?
a few inches of added depth of field on your ancient 50 f1.2 and the overpriced 85 f1.4???
seriously people!
Nothing arbitrary about the 35mm standard. The standard (horizontally), was chosen by filmmakers who wanted a format that as closely as possible mimicked the way we see. Technical issues forced the T.V. to be almost square. With those limitations gone, they could have kept our T.V's 4/3, but who has a square T.V. in the digital age? Even when films are no longer shot on film, the digital motion pictue cameras will continue to mimic the size of a 35mm frame (they already do!!). Coincidence? Why try and reinvent the wheel?
01-28-2011, 03:46 PM   #50
RioRico's Avatar
QuoteOriginally posted by valarie Quote
Well, part of it is arbitrary. IIRC Thomas Edison (whose shop built cine cameras) wanted a wide film stock and had George Eastman (whose shop made film etc) produce film 70mm wide. Turned out that 70mm was better for still cameras (and survives on 120/220/620 reels) and splitting it in half down to 35mm was better for cine. IIRC the first 35mm still cameras were built as test-beds to evaluate cine film stocks and lenses.
I don't recall the details of how the 3:2 aspect ratio was developed, as opposed to the 5:4 and 7:5 formats used by view-cameras, but in cine that was nibbled-away down towards 4:3 by adding optical soundtracks to the film. And there are multitudes of cine formats, an interesting history to follow.
I would like to see (but probably never will) an interchangeable-lens digital camera with a big square sensor, with the option of changing aspect ratios without twisting the cam body around. A big round sensor would be almost as good. I know, I rob a few mini-marts and buy that new 80mb sensor back. That will give a lot of real estate for cropping, eh?
01-28-2011, 04:52 PM   #51
jsherman999's Avatar
Any reason why a 2.5 yr old thread was brought back from the grave?
01-29-2011, 06:38 AM   #52
valarie, you're talking about aspect ratio, not sensor size, if I'm not mistaken.
It seems to me that Pentax FF is deader than ever. With an incredibly high-quality APS-C sensor and a suite of good lenses made for it, there's no longer much point. The 645D is what Pentax did instead.
I suspect there will be fewer and fewer people each year who care about full frame, and they'll buy Nikons or Canons.
01-29-2011, 05:20 PM   #53
valarie's Avatar
QuoteOriginally posted by mabelsound Quote
mabelsound, true, aspect ratio is the most important thing. But sensor size does influence DOF. I have always used small sensors on T.V. cameras, I am not a ff die hard. I think that the smaller sensors are great. They allow you to get the best out of our legacy lenses by not utilizing the nasty edges. I just want fully manual control. I also think Hollywood will always demand a motion picture camera with the same target area as 35mm/film. If not for the legacy lenses, than the legacy knowledge. For stills, we can adapt. For motion pictures, The DP's get paid to much to unlearn a lifetime of information. Working in television, with the technology always changing, we are the ones forced to adapt, and I have no problem working with a variety of sensor sizes.
01-30-2011, 03:45 AM   #54
Movies shoot at half frame, though, 24x18mm.
01-30-2011, 03:54 AM   #55
Moderator PEG Judges
Kerrowdown's Avatar
Alas just a rumour I fear.
01-30-2011, 06:31 AM   #56
RioRico's Avatar
Or in cine speak, movies shot at full-frame, and stills cams shot in double-frame.
QuoteOriginally posted by kerrowdown Quote
Not rumour, just variable reality.
frame, k-mount, pentax lens, slr lens
LX + Scan=Full Frame Digital ziggy7 Pentax Film SLR Discussion 45 01-09-2011 01:59 AM
Is full frame the medium format of the digital era ? ghelary Photographic Technique 2 05-28-2009 08:50 AM
Digital Only or Full Frame lenses JamieP Pentax SLR Lens Discussion 15 05-10-2009 08:48 PM
DA vs FA Limited and the question of full frame digital 8540tomg Pentax SLR Lens Discussion 27 11-29-2008 10:07 AM
Full Frame Digital with DA lenses konraDarnok Pentax News and Rumors 27 08-20-2008 11:07 PM
All times are GMT -7. The time now is 03:02 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
