Originally posted by wibbly if you had room for ONE lens, would you get the 15ltd or the 100 macro?
The two lenses are so very different, so I would choose the one that I would need! 15mm for landscapes, 100mm for portraits, product photos, etc. OR you can choose the one that fits you personally better - some people are more telephoto, some are wide angle.
I have DFA 100mm and Samyang 14mm. I know the Samyang 14mm is not the same as DA 15mm ltd, but I think its a good, more affordable, alternative. Maybe the Samyang 16mm f2.0 would be good, too. But the Samyang lenses are MF, faster aperture, and much bigger heavier lenses. Though, of course the DA 15mm ltd is legendary for its character and is very compact. Just a different overall package.
Anyway, my thoughts condensed: - Which focal length is "better" depends on a) your goal, b) your character
- Neither lens will disappoint you, both deliver amazing quality
- I think the 100mm would be more versatile
- You can get some more affordable alternatives like Tamron 90mm macro or F/FA 100mm macro and Samyang 14mm f2.8 or 16mm f2.0, so you can get two similar focal lengths of nearly the same quality for a lower cost. If you buy used, you can maybe get both of these alternate lenses together for the same total cost as just a new DFA 100mm or new DA 15mm ltd
Originally posted by wibbly assume your other lenses are the da*16-50 and 50-135, 1.4 tc, plus the fa31 and fa77.
If your FA 77mm and 50-135mm lenses fill your telephoto needs, get the DA 15mm. DFA 100 if you want that 1:1 macro
