Originally posted by -spam-
Im shooting a wedding in mid march potentially followed by another early april. I know that i will need some pretty fast glass to handle fast enough shutter speeds in the low light of the church and reception.
On my list at the moment is the Sigma 24-70 f2.8 macro and the Sigma 70-200 f2.8 as well as either another k100d body or a k10d. I think only 1 of my current lenses would be able to handle a wedding situation and that is a manual focus 50mm f1.7.
Is there any other lenses that you would recommend for a wedding or even alternatives to the sigma ones ive listed?
I would forget the Sigma 70-200, and instead get the Pentax DA* 50-135mm f/2.8. The SDM focusing is quiet, fast and reliable. It is usable wide open, and it gives good results throughout the focal range. The 50mm on the short end is handy, and you will not need anything longer than 135mm. It is also msaller and lighter than a 70-200 f/2.8 lens. The Sigma is NOT available with HSM for Pentax mount at present. My DA* 50-135mm arrived today, and it is wonderful. Trust me - this is the lens you want for the longer zoom. It is THE zoom for portrait work on the Pentax mount.
For a wide angle to normal zoom on a second body, you want something wider than 24mm. A Pentax DA 16-45mm f4 would be fine, or the DA* 16-50 f/2.8, or something else that goes to at least 18mm. Stick a flash on the camera with this lens and get in close at the reception.
Skip the prime lenses: you don't want to be fumbling around changing lenses, and you want the instant crop and composition flexibility of a zoom.
Ideally: two bodies, two zoom lenses, two flashes, extra SD cards, extra batteries. An assistant wouldn't hurt either.
