I hate to say this but you don't need a sharper lens, you need to be using the correct technique.
I know of photographers who work with nocturnal animals, and the equipment they work with is very different from daylight wildlife photography. Photographing Nocturnal animals especially ones that fly is very difficult. A common technique for nighttime bat photography is to use sound triggers - bats use echolocation signals to track their prey, these ultrasonic calls they use to "see" increase in frequency and amplitude when they close in on their prey. Photographers use microphones that are sensitive to ultrasonic frequencies, they set them up so when a certain frequency and amplitude threshold is passed, the signal will trigger the camera* which in turn trigger their flash units to allow them to capture the bats while hunting.
Another technique for capturing images of nocturnal animals is to use camera traps which use laser triggering - when a bat (or anything else) breaks the laser beam it will fire the camera shutter - however this technique is difficult to use as laser beams are
very narrow and it can be very difficult to place them in the path of the animals - it is hard to predict where bats will fly, they don't fly the way birds do: they tend to move erratically.
You could also use a focus trap, when you can see a bat passing through a pre-defined area where you have your lighting set up, you can trigger your camera manually - using flash units with modelling lights would be a good idea for this - moths are attracted to light and this will increase the probability of you capturing an image. Any lens can be used for catch focus work as most 50mm lenses when stopped down to f/5.6-f/8 perform identically**. Using a longer lens will reduce the chance that you will catch an image of a bat with this technique - any wide lens could be used, most wide angle lenses perform reasonably well at small apertures.
* Using multiple cameras at different angles slaved to the same triggering circuit is also common to increase the number of viable images.
** I own 181 50mm lenses, there are some 50mm lenses that don't perform well no matter how much you stop them down, there are also some 50mm lenses that are capable of exceptionally high resolution compared to their peers, but the truth remains -
f/8 and be there.
Originally posted by Paul the Sunman DA 70 is sharper edge to edge than the FA 77
The FA77 has higher peak resolution.
