Originally posted by Conqueror The 200 does look pretty decent... perhaps not held in quite a higher regard as the 300 though .. I have some particular shots in mind that I reckon I'll need something 200-300mm for
The DA*200 is a very good lens indeed!
If at all it's not as "well known" as the DA*300, that might be because many telephoto users are looking for a birding lens, in which case 300mm (or even longer) would typically be more suitable.
I don't do bird photography, but I do quite a bit of telephoto work, and have found the DA*200 to consistently yield impressively beautiful pictures.
Technical issues centre mainly around some purple fringing in high contrast scenes at wide apertures, which can be controlled by PP; and average AF speed (very good AF accuracy though, on K-3).
This lens readily delivers the classic Pentax colours, contrasts and micro-contrast - excellently rendered.
It also gives beautiful, smooth bokeh, and yields impressive resolution of detail. Specifically, results at f2.8 are well pleasing to the eye.
I also use the DA*50-135 - a lens I hold in VERY high regard. When compared against the 50-135, the 200 will initially seem "less contrasty". But that's only because the former is a lens known for its outstanding contrast. Whereas the 200 gives more "typical" contrast, more "delicate". But for the manner in which it renders fine details, and the overall image character/purity/quality, the 200 is a prime lens as opposed to a zoom, and delivers accordingly.
Superb build quality - all metal. Truly solid feel, with good weight and balance on K-3. Nice hood with rubberised edge, allowing you to temporarily stand the lens vertically (but with caution, lest your camera fall over).
All said, a lens that consistently produces very beautiful pictures.
