Originally posted by drypenn Then, you're absolutely correct if you intended to type "limited"
But, I've always wondered why Pentax did not name the DFA 100 WR macro a "Limited". The build is obviously "Limited". It is probably one of, if not, the sharpest lens in current Pentax line up. If Pentax made it a "Limited", then it would have been the first WR prime
So there are a few primes that are WR then, the DA* 55, the D FA 100 WR, the DA* 200, the DA* 300 and DA 560 AW - quite an odd assortment with heavy emphasis on the telephoto end of the spectrum. No wide primes or even normal primes that are WR or AW...
