Originally posted by alamo5000
If you want to reverse any DA Limited non aperture ring lens.... put the lens on your camera like normal. Set your desired aperture. While the camera is ON remove the lens from the body.
It will be at whatever aperture you set it at.
I don't know how good this is for the lenses or camera but it works. I have used several of the DA limiteds for macro work while reversed.
It works with Canon (which has aperture motor in-lens), but all K-mount lenses have just "stupid" (ie no electronics at all) spring-loaded aperture lever. Once the lens is removed from camera, aperture closes to the value defined by aperture ring.
If lens has no aperture ring, then aperture goes full close.
To keep aperture open, you have to pull aperture lever towards full-open and just fix it in that position. Everything that keeps aperture in place and does not damage the lens is OK. Unfortunately, a toothpick is little too thin, but safety match is OK, so does small piece of cardboard or so. Just make sure that object is not going to fall into the lens!
Unfortunately, setting precise aperture is hardly possible this way, as it requires very precise aperture lever positioning with no feedback.
