Originally posted by manstanox I have just bought the same lens (Sigma 17-50) from SRS in UK. The box was labelled correctly without including the OS label. The warranty sticker and the serial number on the lens both checked out OK. I guess you just got a rogue box. However, it is worth checking out the serial number - mine is in the 14.7 million range (if that is any guide?).
Serial number of my copy is also in same range, 14.7 million.
Originally posted by VisualDarkness Yes, but the base template is probably the same, with only the Pentax part as a variable.
Yeah, that can happen.
Originally posted by DavidSKAF3 Do you use Lightroom? Does Lightroom recognize that Sigma lens?
Dave
I do. Lightroom does recognize the lens (Pentax mount in particular) but it didn't apply lens profile automatically. I had to manually select the lens from the list.
Edit: Now when I see carefully, the EXIF doesn't have Lens information at all. That's why Lightroom didn't pick it up automatically.
