To answer the OP's question: No!
But it's a good question, because I used to think Super Takumar 50/1.4 serial numbers started at 1000000 (ish).
However, I now know there are serial numbers below that, because last year I purchased one. Serial number 998134.
And my lens is by no means the earliest; I've seen two other lenses on the web with numbers well below mine. (If I can find the numbers I wrote down I'll post them).
Plus there is something else different about the really old versions, as can be seen below.
One of the most famous little red lines in Pentax lens history...to the right of the 4 it's the early one. But few lenses (I believe) also have the red R below the line. Your lens, for example, only has the red line. The ones with the R as well seem to be the very early ones.
