02-01-2015, 10:34 PM   #1
FA* 24mm Hood compaitibility
I have seen the question pop up a few times, but never really seen a definitive answer, other than the pentax 6x7 lens hoods dont fit it.
Does anyone have the 16-45 or the 17-70 as well as the FA* 24mm that can confirm PH-RBB67 or the PH-RBM67 fits the 24?
It seems that finding a hood for a FA*24 is next to impossible.
02-01-2015, 10:40 PM   #2
Sandy Hancock's Avatar
I doubt it. The hood of the FA*24 has a very different system from the DA* hoods. In fact, when you reverse it for storage, you need to rotate it in the opposite direction to make it engage.
I certainly can't get the hood of my DA*50-135 to fit.
02-01-2015, 10:41 PM   #3
Based on the way the bayonet is made I don't think those other hoods will work, but I haven't tried so I'm not 100% sure. You could always use a round rubber hood okay.
02-01-2015, 10:42 PM   #4
Well I have one of each hood(although I think they're both identical) on the way so I'll find out soon enough. I was just seeing if anyone else had tried it since a lost hood for the 24 is so hard to replace.
02-02-2015, 12:27 PM   #5
I have both lenses (DA 16-45/ FA 24mm) and hoods:
Petals are slightly larger on the original 24mm hood.
Mounting a PH-RBL onto the 24mm is not possible.
02-02-2015, 12:32 PM   #6
QuoteOriginally posted by ChrisFe Quote
Well good to know, Thanks for the info.
24mm, fa*, fa* 24mm hood, hood, k-mount, pentax lens, slr lens
Lens Tournament: FA* 24mm F2 vs DA 12-24mm F4 Adam Pentax Forums Giveaways 4 10-26-2014 01:21 PM
Hood for the FA* 24mm/2 matsoberg Pentax SLR Lens Discussion 15 06-06-2013 08:27 AM
All times are GMT -7. The time now is 10:18 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
