02-05-2015, 08:28 AM   #1
kp0c's Avatar
DA* 50-135mm lens hood replacement - would a Canon hood fit!?
I have a DA* 50-135mm with missing hood that I got for a good price. Obviously, I now want to purchase a hood to pair with the lens as I much prefer use a hood for protection and for optimal IQ.
Anyway, I can't seem to find the original hood online for a reasonable price (I could find one for 50$, but looking at cheaper option for now) and was wondering if any of you guys knew if using a Canon replacement lens hood could somehow work with the Pentax lens. Here is an example of a hood I have in mind http://www.amazon.ca/Dedicated-70-300mm-Replacement-MagicFiber-Microfiber/dp...hood+telephoto
I know it's a LONG shot, because for the hood to fit, things need to be align and diameter of the lens must be pretty much identical, but I thought I might ask, just in case...!
Anyone out there have replaced their DA* 50-135mm? Let me know what product you picked and how it turned out!
Thank you for your help.
02-05-2015, 09:23 AM   #2
UncleVanya's Avatar
I'm I the same situation. I am using the hood from my DA* 60-250 or my screw-in 67mm from my A* 85. Any 67mm screwmount short tele or normal hood would be a potential candidate hood. If needed I can give you details on the length and width of the shortest point on the original hood (same as the 60-250).
02-05-2015, 09:30 AM   #3
I have two 67mm hoods from other pentax zooms. I'll check them on my 50-135 and see what they look like . . .
02-05-2015, 09:39 AM   #4
aleonx3's Avatar
I would buy the original hood if I were you....
02-05-2015, 06:32 PM   #5
kp0c's Avatar
I know the original would be the best solution, but the only one I could find was on the other side of the ocean and 60$ or so...
02-05-2015, 07:08 PM   #6
i_trax's Avatar
Pentax PH-RBK 67mm Lens Hood 38754 B&H Photo Video
Pentax Ph RBK 67mm Lens Hood for Pentax Da 60 250mm F 4 Ed | eBay
02-05-2015, 07:28 PM   #7
UncleVanya's Avatar
QuoteOriginally posted by Marktax Quote
The 60-250 and 50-135 have similar needs so they use the same hood. The other 67mm hoods are often a lot shorter designed for a wider angle - the A* 85mm metal hood I have is wider but just about exactly the same length as the shortest part of the hood designed for the lens. It isn't as strong a coverage since a round lens hood doesn't provide the same level of coverage but it is pretty good.
50-135mm, 50-135mm lens hood, canon, da*, da* 50-135mm lens, hood, k-mount, lens, lens hood replacement, pentax lens, price, replacement, slr lens
For Sale - Sold: Pentax DA* 50-135mm Lens with Hood - Screw Drive Converted OnTheWeb Sold Items 11 06-06-2014 10:41 AM
How does a lens hood fit in a FA 50mm? julbelle Pentax SLR Lens Discussion 5 04-18-2014 08:12 PM
DA★50-135mm F2.8 ED lens hood querry a a i b Pentax SLR Lens Discussion 23 04-07-2012 01:33 PM
lens hood alternatives for DA* 50-135mm laissezfaire Pentax SLR Lens Discussion 3 05-20-2010 12:26 AM
DA* 50-135mm lens hood FullertonImages Pentax SLR Lens Discussion 6 10-24-2009 08:24 PM
All times are GMT -7. The time now is 07:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
