Pentax M20/4; A50/1.7; M85/2 a very versatile travel kit at a very small size
I do think the M20/4 is the closest in size.
Its also wider, 20mm vs 22.5mm eq.
Surprisingly, less field curvature compared to faster f2.8 20mm lenses.
Perhaps last 1/10 of the frame is less sharp at f8.
No real issue at f11.
Corners are not good at f8 but imo f11 its do-able.
I even printed a shot at f11 to confirm. A4 size print.
Use of aspect ratios like 5x7 or 8x10 immediately removes any of the concerns regarding corners too.
The edges and corners also get cropped off when using distortion correction in LR.
Which in my actual real use, I found to be often the case.
The FA20 is a nice smallish lens.
Here it is compared to a Canon FD20 (roughly same lineage type lens) and the size difference is apparent.
and we are not even talking A20 or M20 here.
I commented on its performance here.
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/285043-what...ml#post3108556
