Originally posted by osv different lenses, but i think i see where you guys are headed.
if he liked the fov of a 135mm lens on crop, he'd need to be shooting 200mm on ff to get the same fov?
but there are radical differences in actual lens magnification there, regardless of sensor size, so it's not an accurate comparison.
i think that where crop sensor people get further fouled up is because most of 'em fail to take pixel density and 100% view on the screen(object size) into consideration.
here are the basics:
DSLR Magnification
the only problem there is that he didn't cover how pixel density affects the view on the screen... this can get rather complicated.
as an example, 200mm on crop is 200mm on ff, period... there is no "magnification", because the focal length of a lens can't be changed.
from there, you can start trying to understand why the picture looks different because of differences in sensor size and pixel density.
...keeping in mind that when 50mp ff sensors hit the market later this year, it going to confuse people who are used to shooting with small high pixel density sensor cameras.
Magnification is not dependant of sensor size or pixel density. A macro 1:1 lens stay a macro lense on APSC or FF.
The bigger the sensor, the bigger the field of view, not even a tiny bit the level of details. This is only the pixel density that will affect the level of details.
And so an FF would need 64MP to match the level of details a 28MP APSC sensor (Samsung NX1) or 145MP to match the level of details of a 20MP 1" sensor (Sony RX100).
From practical purpose, if one display the full image on a given physical size (like a screen or a print) the pixel count of the image doesn't count at all as soon as there are enough. That 2MP or less on most screens, 8MP on 4K display, 16MP for a 300dpi "perfect" print 16"x12" print and 150 dpi on an already really good 32"x24" print. Even printing at 75dpi for 64"x48" would be quite ok as to see the details you'll have to look at the picture from nearer distance than what a normal viewer would do.
From a practical point of view if you expect the viewer to see the whole frame at a time from a normal distance, you don't really need that many pixels. Something like 5-10MP is plainty enough.
So what 50MP is for ? To have more latency to crop/reframe the image if needed. For example to extract a pano with enough pixels. Or then to provide perfect quality image for huge image and still be able to go near and see tiny details. But to really do that, 50MP is not even that much, photographers that are after that tend either to use big film camera and scan for 200MP+ or to merge many assembled pictures to have pictures of 1000MP or more.
The only thing to keep in mind from all this crap is the bigger the sensor, the wider the angle of view you'd get out of a given focal length (and the more shallow will be the deph of field for the same apperture). This is conveniant to shoot wide angle landscapes for sure, but this is not that conveniant if at all to shoot from a distance something like wildlife where every few mm had a significant cost and weight to the gear.
