Show Printable Version 4 Likes Search this Thread
02-12-2015, 11:55 PM - 1 Like   #16
Lowell Goudge's Avatar
QuoteOriginally posted by igabc Quote
Guys please point me to a good zoom in the range between35-150 and 70-200
For my new K3. I'd like to stay below 300 dollars
Love
Gabriele
AF or MF?
If you want MF and can find one, a vivitar series 1 70-210 F3.5 ( first version of the lens with constant aperture). Sharp, fast easy to use as it is a single ring push pull zoom, reliable and quick to focus with 180 degree throw from minimum to infinity, but enough throw to be accurate. It is a true zoom, so bulling straight back does not change focus, and it can do 1:2.2 macro with no adaptors. They usually go cheap,mount are very high quality
---------- Post added 02-13-2015 at 02:02 AM ----------
The range is too big. I consider this lens to be a very good one for those who choose to have ONE multi purpose lens, only one.
Thank you
---------- Post added 02-13-15 at 12:18 AM ----------
Ok after 3 hours spent on this topic, reading all the reviews about the lenses you suggested, I think I have more clear what I need...
manual focus: important
sharpness: important. but maybe post production will help.
CA: I can't compromise here. can't be fixed in post.
weight: not a problem
not too big zoom range. I rather buy 2 higher quality smaller range zoom lenses, rather than 1 big range.
performance in low light: important but the K3 is amazing at high iso so maybe that will help where the lens lacks. Plus, a good flash is always on my camera. Guys, do the same. Light is almost never perfect out there so flash, always ready.
I love the idea of a full frame lens, as it won't matter if it loses image quality at the corners and edges. nice.
Bokeh: important. I don't get it...I've read someone complaining about a bad bokeh on a zoom lens at wide. bah!
auto focus speed: not important at the moment. manual focus is more fun and challenging.
Maybe I'll go for the 50-300
Do I make sense?
P.s. I think those who write reviews should never miss to state the cameras they tested the lenses with.
Ok, so in reading this,myounwant to use flash, so, any lens must be KA or later to use your flash , so strike the series one lens I suggested,
One thing to note, you are wrong about CA. With the right post processing tools Lateral CA can be easily fixed in post processing, as can purple finding, but sharpness cannot.
Also note that edge sharpness and lateral CA go hand in hand. I did a series of posts looking at a lens that had very bad lateral CA. Pentax photo lab , Photoshop, and many other programs and photo shop compatible plug ins have lateral CA correction which is done by rescaling the three Color layers. Lateral CA is the result of slightly different magnification at different wavelengths, and if your CA correction works by rescaling the color layers (by changing the magnification of each) you can almost completely eliminate it, and the resulting improvement in edge sharpness is quite noticible
02-13-2015, 06:55 AM - 1 Like   #17
UncleVanya's Avatar
W-o-w!
---------- Post added 02-13-15 at 01:48 AM ----------
bought the 18-135 WR
I think it's a must have.
Next will be a pro flash.
Thanks a lot everybody!
G
Awesome! Glad I remembered to mention it. That is a fun lens.
02-13-2015, 08:47 AM   #18
igabc's Avatar
AF or MF?
Found one. Working on it. Thank you!
02-26-2015, 11:11 PM   #19
igabc's Avatar
ok I am back to this thread, after 1 week playing with the new K-3 and the 18-135.
I learned that not all the lenses come out good. Maybe mine was one of the bad ones. I am really disappointed of the sharpness of this lens. CA, Bokeh, colors and overall quality is very good but the details are really bad so, I am going to return it.
The sample pictures in the dedicated thread here on Pentax Forums are very good, but they were resized down so, you can't tell how good they were at full resolution.
I found this comparison https://www.flickr.com/photos/47244597@N00/sets/72157640900479083/with/12489252175/
The difference is impressive to me. I'll go for the Tamron but maybe I'll get the 24-300
According to the review on PentaxForums Tamron SP AF 24-135mm F/3.5-5.6 AD Aspherical [IF] Lens Reviews - Tamron Lenses - Pentax Lens Review Database the Tamron seems worse than the Pentax, but those images on the test from Mark Hoffman speak clear.
02-27-2015, 06:27 AM   #20
TER-OR's Avatar
If the lens is under warranty, send it in for evaluation.
02-27-2015, 06:34 AM   #21
Driline's Avatar
Don't feel bad. My DA 18-135 wasn't up to par either so I sold it. Hey that $50 Pentax F70-210 is still waiting for ya I found it much sharper than my DA 18-135. What's to lose?
02-27-2015, 08:49 AM   #22
ChristianRock's Avatar
Based on your requirements and price range, I recommend the following:
SMC Pentax-A 35-105mm f/3.5
SMC Pentax-A 70-210mm f/4 Macro 1:4
They are manual focus lenses but otherwise have the "A" contacts and will work with all your camera modes. I have the A 70-210mm and it's surprisingly easy to focus, a joy to work with and renders wonderful colors. The 35-105 I don't have but it's universally praised. I'd throw in an A or M 50 1.7 in the mix and you should have a nice setup, just add a wide angle later.
02-27-2015, 09:24 AM   #23
I actually believe that in terms of longer focal lengths, AF is more important (because of the narrower built-in DOF).
Actually, no. Most CAs can be fixed in post (if you shoot RAW and use a good raw converter such as Lightroom).
02-27-2015, 10:34 AM   #24
igabc's Avatar
QuoteOriginally posted by northcoastgreg Quote
Yes, II've been corrected about this here in this thread by someone else. Thank you though.
---------- Post added 02-27-15 at 12:35 PM ----------
QuoteOriginally posted by Driline Quote
Where is it?
---------- Post added 02-27-15 at 12:42 PM ----------
I've been sending hours yesterday reading lens reviews.
I want sharpness above 8.5, decent and precise manual focus, I don't care about autofocus, A lenses preferred but a can even Go for the old manual lenses above 135 because I have then almost all from my old MX.
I want great sharpness, colors and contrast. I can compromise on vignetting, autofocus, weight...not important.
Ok I'll get back to you later.
Thank you again!
02-27-2015, 12:31 PM   #25
Driline's Avatar
Where is it?
Thank you again!
Ebay. I just bought one a few weeks ago for $40 and purchased its cousin the Takumar version for $25. So far I can't tell the difference in IQ between the two. They both look exactly alike.
---------- Post added 02-27-15 at 01:35 PM ----------
There's one right now on ebay for $49.99 or best offer.
02-27-2015, 04:12 PM   #26
igabc's Avatar
I can't find it. Can u pls send me the link?
I found one for $109 but I rather spend 50 :P
---------- Post added 02-27-15 at 06:22 PM ----------
QuoteOriginally posted by ChristianRock Quote
Hello Christian and thank you for the suggestions. I was actually looking at those 2 lenses last night and I am bidding already.
Thanks again!
02-27-2015, 04:28 PM   #27
Driline's Avatar
Pentax F SMC AF 70 210mm F 4 5 6 Autofocus Lens 1986 1990 | eBay
I'm not sure about the separation ring thing, but the ones I purchased were perfect. Maybe wait a bit for the right one to come along.
I don't see a Takumar version right now, but they should be about $25 or so.
Time is your friend when it comes to ebay
---------- Post added 02-27-15 at 05:34 PM ----------
Here, I found one at KEH for $56. https://www.keh.com/241282/pentax-70-210mm-f-4-5-6-takumar-f-k-mount-autofocus-lens-49
KEH is highly regarded on these forums.
(Our 180-day, non-transferable warranty allows you to buy with the assurance that your purchase is seamless and hassle free.)
02-27-2015, 06:56 PM   #28
igabc's Avatar
OK I remember this lens was suggested here in this thread, days ago. I didn't buy it because of the small manual focus ring.
I just bought this one: Vivitar 80-200mm F4 MACRO FOCUSING ZOOM MC Lens Reviews - Vivitar Lenses - Pentax Lens Review Database from Canada, for USD 34 on ebay. Hopfully is in good shape, as it is a non-return deal
I want an AF as well so maybe I should go for this one you found on KEH.
I've seen your lens list on your profile page. You have good words about the AF 35-70 but I can't find it online to buy it. I found this one Pentax AF 35 70mm F3 5 4 5 SMC Takumar F Lens 396 | eBay - is it the same lens?
thanks!
02-27-2015, 07:14 PM   #29
Driline's Avatar
Yes same lens. I also found this actual Pentax F 35-70 on ebay for $40 buy it now. That's a good price. 35 70mm 35 70 3 5 4 5 SMC Pentax F Some Interior Dust and Debris 179255 | eBay
02-27-2015, 07:28 PM   #30
igabc's Avatar
SOME INTERIOR DUST AND DEBRIS
LOL
PS: they just sold the one I linked you to. It was you!
autofocus, da, dc, ebay, flash, focus, hsm, k-mount, keh, lens, lenses, macro, pentax, pentax lens, photo, post, quality, range, reviews, series, sharpness, sigma, slr lens, smc, tab, wr
Do I need to buy the FA31mmf1.8 if I have the K28mmf2? Pepe Guitarra Troubleshooting and Beginner Help 15 10-29-2014 02:03 PM
Photography Qualification, do I need one to further my career? MarisaG Photographic Industry and Professionals 11 01-23-2014 07:46 AM
Please help, i am about to buy a k-30 and i need some advice (mabe a lot). carlosodze Pentax K-30 & K-50 15 05-20-2013 11:11 PM
what this thing called, I need buy one liukaitc Pentax Camera and Field Accessories 5 06-08-2011 03:16 PM
Cant decide which one to buy? Need Help Atindra Pentax SLR Lens Discussion 10 10-24-2008 02:22 AM
All times are GMT -7. The time now is 01:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
