I agree with creampuff .
Dave : just use your kit lens .
Have the camera on tripod .
Set the ISO to the lowest . Aperture to F16 or so .
Compose your image . Focus then slowly put on your R72 .
Use the remote or cable switch to minimize the camera shake .
I carry a lens cloth to clean the lens and filter the last minute . It's a long exposure so anything dirty will show up on your photo . Make sure you cover the viewfinder with the cap before firing .
Here is one with the DS at ISO 200 , F16 , 1.5 sec :
You can use the K10D too . I use it in B mode . Just use you watch . Very much the same set up . Compose , focus then switch to the B mode . Count and pray
. I believe in multi Gods . Just like a muti life insurance policies , j/k
I shoot on K10D with different timing for each image . After a while you will have somewhat of a timing down .
K10D with FA50/1.4 ,ISO 100 , F16 , 108 sec :
If you leave the ISO on AUTO , it will pick up a higher setting so less exposure time . But I prefer to set it in lower ISO for less noise .
More images at
Infrared - a set on Flickr
Good luck and have fun .
Tran
