02-15-2015, 10:12 PM   #1
piggyback lens adapter solution viable?
Have you ever heard of anybody trying or is there any reason why I should not try using a piggyback combination of a replacement lens mount + lens adapter to mount an old manual focus lens on the K-5?
The reason is I have a 28mm Leica R Elmarit f2.8 lens that I cannibalized a while ago by replacing the original Leica lens mount with a very nice Leica R to Sony Alpha replacement lens mount that took a bit of patience as I am no expert but turned out very well...
until I dumped my Sony and bought a K-5
only to discover afterwards the only way I can mount my Leica R lens on the K-5 is by spending a pretty penny to cannibalise it all over again this time with a Leica R to Pentax K replacement mount.
until I got another bright idea that is why not mount my Leica R lens that already has a replacement Sony-A lens mount via a Kipon or Fotodiox Minolta MD* to Pentax K-mount adapter on my K5, as this would be (a) cheaper, (b) require less surgery than replacing the lens mount again, and (c) enable me to retain the option of using the same lens on a camera with a Sony A-mount if I ever want to do that again too,
But maybe this is not such a bright idea ie unworkable?
Since as I mention earlier I am no expert and new to pentax any advice about the viability of this is most welcome!
p.s. *as you surely know if you have read this far is Minolta MD is same for all practical purposes as Sony A-mount)
02-15-2015, 10:20 PM   #2
jatrax's Avatar
I believe there are MD --> K-mount adapters. However they will have glass elements in them to correct for the different registration lengths. Which might end up reducing the image quality enough that it is not worth the effort. If the purpose is just to shoot with the Leica, then it should work. But I'm not sure that you would be better getting a native k-mount 28mm such as the Pentax-A 28mm f/2.8.
02-15-2015, 11:34 PM   #3
UncleVanya's Avatar
Additionally the glass element lens adapters act like Tele converters so your 28 acts more like a 42mm... and that's before crop factor is applied.
02-16-2015, 03:37 AM   #4
Not a Number's Avatar
The Alpha mount is not compatible with the MD (SR) mount. The bayonet is different, the registration is different, the aperture controls are different. That's why I never went up to Minolta autofocus cameras because my MD lenses couldn't be used and I'd have to buy new ones.
You'd have to get the Alpha mount to K mount adapter, which also has an optical element.
a-mount, adapter, k-5, k-mount, leica, lens, lens adapter solution, mount, pentax, pentax lens, replacement, slr lens, sony
M42 adapter stuck (solution) vanyagor Troubleshooting and Beginner Help 41 06-12-2017 12:16 PM
DIY lens cleaning solution ??? Schick Troubleshooting and Beginner Help 27 10-13-2014 06:18 PM
Solution to Genuine Pentax M42 Adapter problem! virgilr Troubleshooting and Beginner Help 4 08-28-2013 07:26 AM
M42 Adapter question or non-permanent solution for Fujinon 55mm f1.8 toukan Pentax SLR Lens Discussion 16 01-16-2013 04:51 PM
Lost DA35 Ltd Lens Cap. What viable alternatives? raider Pentax SLR Lens Discussion 10 11-28-2010 03:03 PM
All times are GMT -7. The time now is 03:58 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
