Originally posted by Class A First, as the variations occur amongst copies, as opposed to between models, the profiles would have to be copy specific. Some of the variations are actually captured in lens memories, but, second only some aspects of lens variations are captured.
This sounds like speculation. It seems like a lens would have to be a pretty bad copy to require its own unique profile. But sure, there's always going to be a certain number of bad copies. That's what the warranty and/or exchange policy is for.
Originally posted by Class A I'm further assuming that there are tolerances for lens mounts and sensor positioning as well.
I don't think variations in mounts or sensor position would come into play. AF is performed
on the sensor, so there will not be a discrepancy between the AF sensor thinking everything is sharp, and the image sensor capturing something less sharp. That's what happens with DSLR's, because focusing is
not done on the sensor.
Originally posted by Class A Your experiences with mirrorless AF may be positive, but most PDAF experiences are also mostly positive
You don't have to spend a lot of time on a DSLR forum to hear people talking about this lens or that lens back-focusing, front-focusing, or focusing inconsistently. These kinds of complaints are a staple. There's a reason that DSLR makers have begun including AF adjustment in their bodies. There's a reason that people have played the "lens lottery", and have returned multiple copies before getting one that works well with their particular camera body.
As far as I know, mirrorless cameras don't even have the AF adjustment "feature", which is logical since they aren't subject to AF sensor / image sensor discrepancies.
Originally posted by Class A I don't know how slow/fast your experience was and how challenging the lenses were.
I'm currently using the Olympus 75mm 1.8 on my Panasonic GX-7, and that lens has a very shallow depth of field, so any problems would be very evident. I also have the 20mm 1.7. In the past, I've owned the Lumix LX-100 which has an m43 sensor and a fast zoom lens, and I also owned the Sony RX-1, which has a FF sensor with a 35mm f2 lens.
