06-02-2008, 12:03 PM   #16
ChrisPlatt's Avatar
Rikenon P lenses may have the pin; XR Rikenon lenses do not.
Chris
06-05-2008, 08:26 AM   #17
columbus's Avatar
QuoteOriginally posted by ChrisPlatt Quote
Actually it's the opposite; the camera (or your finger) must overcome the spring pressure holding them closed.
If the opening does not change size as you rotate the aperture ring you do have a problem,
either a broken spring or gummed-up blades...
Chris
That's what I thought.....but the appeture ring changes the metering when it's mounted on the body (ricoch kr-10) when I rotate it.
appeture, k-mount, lens, pentax lens, slr lens
All times are GMT -7. The time now is 11:49 AM. | See also: NikonForums.com, part of our network of photo forums!
