Originally posted by candgpics I am paraphrasing, but he told me that DSLR cameras are using an “ancient" focusing system and are often not able to handle new “esoteric” lenses, such as the 18-35.
Technically true, but other lenses still manage to perform well. Even fast aperture lenses.
Originally posted by candgpics He mentioned, though I did not quite grasp it all, the difficulty the mirror in a traditional DSLR system introduces to focusing
Also theoretically true, but not backed up by experience.
Originally posted by candgpics He also noted, after I mentioned that I turned shake reduction off, that the sensor assembly due to its shake reduction capability still causes a problem.
It shouldn't have any impact.
Originally posted by candgpics I was specifically told to set the lens up at 1 meter distance at 35mm, at 1.8 and focus on a 3D item, not a chart. This sounds much like the follow-up testing pentaxforums did, but I will give it a try.
A 3D object introduces a new variable in the equation.
The Pentaxforums tests are rigorous, well detailed, and as an optical designer often responsible for products qualifications, I find no significant faul with it. It documents and demonstrates the problem without doubt.
