Originally posted by normhead huh?
The APSC framing is smaller than the FF framing. When the 2 sensor are said to have the same MP (eg K3 & A7 for example) if you take a crop of the FF to match the APSC area you'd get 10MP. 10MP is less demanding for the lense than 24MP and thus easier to max out.
A lense on FF need only 2/3 (1/1.5) on the lp/mm to cap the sensor resolution in the center because the pixels are much bigger.
So the question finally is how much quality your lense can deliver. Your hypothesis normhead is that any lense is so good that it cap any sensor, and so it is mostly the sensor that will change the performance.
The reality of measurement is different some lenses have very high resolution and, as an example macro lenses tend to perform better than some other. High end lenses tend to also perform better than some others. This mean their resolution in corners might be better, the overall contrast might be better and the resolution again might be better.
As said here, Sigma 35 Art gain more resolution from K5-IIS => K3 than many more lenses. This mean this lense has more margin than many.
If we look at DxO what do we get by going from K5-IIs to K3, counting in theory we should get 50% more MP on their score if the lense was perfect:
- DA20-40: 9=>9MP 0%
- 18-270: 6=>7MP 16%
- DA35 macro: 12 => 13 8%
- DA55-300: 7 => 7 0%
- DA70 ltd: 10 => 11MP 10%
And if we compare K5 => K3:
- DA20-40: 7=>9MP 28%
- 18-270: 5=>7MP 40%
- DA35 macro: 9 => 13 44%
- DA70 ltd: 8 => 11MP. 37%
Most of the difference in fact as explained comes from the low pass filter removal. The best lenses like DA35 macro and DA70 ltd still see more improvement by going to K3 but low end lenses like 18-270 or DA55-300 do not see that much improvement.
For me I have no issue with that it really match what I observe:
- I saw most of my lenses being better from K5 => K3 but of course I don't know what is more responsible for it: added resolution or low pass filter removal.
- I see that my best lenses are sharper/better than the worst one, very noticably. We can really see it DA18-270 is much worse than DA35 macro for example.
If we go back to APSC vs FF, FF need less lw/mm to achieve the same picture resolution in the end so at least in the center it is less demanding than APSC lenses.
