Originally posted by audiobomber The sharpness score tells you about sharpness. Since when is sharpness the determinant of a great image? Is it even in the top five? Sharpness is a useful technical aspect of a lens.
Furthermore, the sharpness score is a single number intended to generally describe the sharpness of a zoom at all apertures, at every focal length and across the frame. No single number can tell you everything about the lens, and DXOMark says so, quite plainly as I quoted above.
This at least give some indication that for example if you want to print large you'd want at least some sharpness level. And if you want to crop the image, you want some margin too. What K3 has given to me with great lenses is more margin for reframing. it is not essential all the time but it is usefull.
Thoses shoots of 18-200, if you crop them a bit too much, it will show. And the image of normhead with the 700 likes to me look lke uninterresting and not sharp even on the very small size he has given. I think this is more due to facebook terrible Jpeg compression than anything else. And I find it uninterresting because I'am not found of bird picture to begin with, the borders put on the photos and the colors rendering. But it is just me, art is not always universal.
But what the likes really means? That most would really prefer this photo on the living room than another one that is less liked? That they really feel it is better?
For me, it is because the subject is funny, a rare thing to have this kind of bird to show at all and the composition is quite good. The normhead photo has value because it is an original one. Normal people don't look at the artistic value or the technical merits. They would not recognize a real monet with than something similar made by anothe artist with similar technique.
Does it means that people would not prefer the same photo with better light, if facebook didn't over compress the thing, if the composition was even better? Of course. But this alternate version is not present to compare. And between 2 photographers if the one with the better photos (even just what he took, not at all the technical merits) has less contacts on facebook or don't make effort to promote it, it will not be seen. But even a very average photos with good promotion with get thousand, hundred thousand like or maybe even make it to flickr explore because of the power of the community the photographer managed to make arround it.
As to the camera and lense, it is a part of what help the photo shine. Depending of the subject, the gear and so own it can be more or less important, but it has it's usage. A lensbaby is not sharp and is quite creative and interresting in some case, totally counter productive in others. The good photographer doesn't conclude no lense ever sharper than lens baby is necessary but instead think of when to use it and when not to use it !
And we need some logic too. When you rate a lense, you rate a lense. You show what it is. That the goal. The numbers of DxO are neutral. Many for example think the number of Pentax lenses are bad but when you read DxO reviews of for example DA20-40 or many ltd, DxO is quite positive about it in their explanations. They don't say the lenses are bad at all. When one choose the gear and so on, he should also know something about it.
Despite all that is said you'll see the difference between a DA*55 and a 18-200 in pratice at least for deph of field. And when taking some macro shoot, or when shooting wildlife, more pixels can also be quite handy.
That the same when you buy a car, you should choose the motor power depending of your intended use. If you plan to just go to work with lot of traffic jam you don't need that much. If like a friend you need to carry a horse from time to time, you need a powerfull car with the capacity to handle the heavy load. If you want to feel the car and drive fast in small roads, a sport car might be better. Does it means that everybody need the powerfull motor needed by the sport car or the SUV to carry the horse? Well hell not. Is it bad or good? It is simply neutral. It is your car, your life, your money.
Like for the photos, it is your camera, your lenses, your photos, your money. Choose wisely for the intended use.
