Originally posted by UncleVanya what body you used and what process you used
At first you have to get in debug menu to access lens rom (lenseep.lns file) and save it to SD card.
I used K100d body because with this body is more easy to get into debug menu.
1: Hold INFO and AE-L then power up
2: Press MENU, MENU then INFO in 5 secends
3: You now enter the debug mode
4: Press MENU once
5: Here you go!
It is possible also with other bodies, just search the forum:
https://www.pentaxforums.com/forums/10-pentax-slr-lens-discussion/208353-how-...m-f-2-8-a.html
After I used Notepad++ on my pc to edit lenseep.lns (make copy before editting!!!)
Then copy edited file to SD card, enter debug menu once again and load sdited file to lens. That's it. It's easy.
