12-09-2018, 07:48 PM - 2 Likes   #31
K-Three's Avatar
Wow, my words from the deep past. Had to do a bit of googling and playing around with lenses,
Found this page with some equations and a bit of high school algebra,
With crop sensor, APSc format, cover a 20x24 field of view at:
The 35mm about 3-feet
A 50mm about 4.2-ft
and 100 takes about 8.5-ft
I'd use the longest lens you can given the space and the art size. It's easier to be square to the work when you are back further from it. Also, you need some space to get your lights in without casting shadows from your camera on the art. If doing it occasionally, I'd play with a zoom lens, if you're serious, and doing this often, or need great results for reproduction or enlargements, I'd go with a good prime, likely a macro, for flatter field, and less drop off in the corners,
Let us know how it works out for you
12-10-2018, 09:05 PM   #32
QuoteOriginally posted by K-Three Quote
A 50mm about 4.2-ft
A long lens will also cause less spatial distortion, as the edges of the artwork will be approximately the same distance from the lens optical center as the center of the artwork.
12-12-2018, 03:24 PM   #33
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by TAP Quote
Best Lens for Photographing Artwork?
Another +1 for a macro lens, in my case I'd recommend the “Femme Fatale” (Pentax-A 50mm F2.8 Macro).
12-12-2018, 06:27 PM   #34
QuoteOriginally posted by Kerrowdown Quote
The A50/2.8 is a fine lens.
12-12-2018, 07:09 PM   #35
PEG Moderator
Kerrowdown's Avatar
QuoteOriginally posted by civiletti Quote
Indeed she is.
12-27-2018, 08:37 PM   #36
Sorry it took so long to thank everyone for the replies, I was having trouble getting signed back in and then, Christmas.
The angle wizard link was really helpful, and combined with the remnants of my geometry from memory, has me confident that I can go ahead with a 100mm macro in the space I have. I did want the long lens to minimize any distortion because I also want to play with stitching to attain some really high-res results, and so the edges become especially important. (Here’s to hoping someone has some optimized software for stitching a matrix of close-ups into the larger image; if I have to do that manually in Photoshop it’s probably a deal-beaker. &#128556
Again, thanks to all for the advice!
12-29-2018, 08:03 PM   #37
K-Three's Avatar
QuoteOriginally posted by ramatsu Quote
for stitching you want to overlap each frame by 1/4 to 1/3, if done right, your edges should not be that big of a factor.
I've done it with the routines in Photoshop Elements, and it does it well if you give it enough overlap to work with.
35mm, 50mm/1.4, artwork, camera, clients, da, focus, frames, improve, k-mount, lens, lenses, lot, macro, macro lens, pentax lens, scanning, sharpness, shoot, slr lens, smc, tak, thanks, time
[Advice] Lighting, lenses, workflow for photographing Artwork carrrlangas Photographic Technique 13 12-23-2013 11:18 AM
Photographing Artwork writerman Pentax DSLR Discussion 6 04-16-2013 07:44 PM
Lens for photographing artwork writerman Pentax SLR Lens Discussion 10 06-24-2012 01:38 AM
Best camera/lens for photographing negatives Kurt Euler Ask B&H Photo! 2 09-04-2011 09:09 AM
Best Pentax lens for photographing food? jacksonpritt Pentax SLR Lens Discussion 4 12-24-2009 05:09 PM
All times are GMT -7. The time now is 09:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
