Originally posted by Greinerstudio Originally posted by biz-engineer Quote Zoom: Tamron 17-50 f/2.8 / Sigma 17-50 f/2.8 on K-3 These would cover a great range. Do the hold up on the low end range in an IQ sense compared to the 18-35? Are they better at 40 than the 40 Ltd?
It depends. IF 18-35 will focus, it would be sharpest from those zooms. Some people have problems, specially with low light and wide end with narrow DOF. It's heavy, you don't hike with this one.
Sigma 17-50 -i own it, is my current standard zoom main lens. It's controversial one. Sometimes slow, hard to use against strong sunlight, flares enough, needs filter use. Bokeh -not best one (7-8)
Heavy, but not so big as 18-35. Very good from 30-50mm, fully or usable enough from 17-30 at F4-11, not so good wide end at F2,8-4, good color, some CA you may get at wide end at low stops. But it's still very good value for price. I move around with bicycle, but there are much easier lenses to handle (weight, filter size)
Tamron 17-50- is vice versa to Sigma - performs well at wide end, soft at long end.
Have not used 17-70 sigma.
If you are not going to primes (15,21,31), want WR and small weight, take DA20-40. It does not pop, but does reliable job on his range. (This one does not have any macro capabilities)... good on landscape or architecture, well but on people or moving subjects- it's quite slow.
Forget DA16-85, if quality matters.
