02-25-2015, 08:15 PM   #1
Getting dust out of lens?
I got a Pentax-M 50mm 1.7 with dust on the inside lens element behind the front element. Is there any way to get in there and clean it?
02-25-2015, 09:03 PM   #2
calsan's Avatar
That's not a problem, leave it alone!!
The dust you describe won't have any effect on your photos (the dust will not stop any light and always be out of focus). Pulling the lens apart will muck up the very precise factory tolerances. That will have an effect - it will ruin your lens.
The only dust that is visible in your photos if is dust is directly on your sensor, even then, you have to be stopped down a lot to see it.
Dust is pretty much a fact of life and best ignored. New lenses come from the factory with dust in them, dust is also created in lenses and sucked into lenses by zooming and focusing.
02-25-2015, 09:21 PM   #3
jatrax's Avatar
^^^ what he said.
You can take the lens apart and clean everything, put it back together and have more dust when you are done than you started with. And take the risk of not getting it back together correctly. Fungus is a different story as well as haze or oil. But a little dust, just leave it be.
02-25-2015, 09:36 PM   #4
If you like horror movies.....
02-25-2015, 09:59 PM   #5
calsan's Avatar
What a butcher. The lens is in great condition at the beginning and hacked to bits by the end. Opened with a pair of scissors.
02-25-2015, 10:14 PM   #6
Stavri's Avatar
Step away from the lens....
QuoteOriginally posted by robthebloke Quote
http://youtu.be/Kz5spB68aok
This video made my day watching that lens depreciate by the second was unbearable, went from $19.99 to .01 in less than ten minutes. I was reminded of my early years when I tried to de-fungus a Vivitar Series 1 200mm f3.0 and scratched one of the inner elements. Now i'm wiser and have stopped bothering about optical cleanliness. I'll resume lens hacking when both my cats are dead and my house is as clean as a factory for assembling hard drives in Philippines.
Most of old lenses have some amount of debris inside, that's a common occurrence which doesn't bother the majority of shooters out there. Dust doesn't usually impact image quality, other things like fungus, damage to coating, lens separation, substantial haze, oils, water etc do, depending on the scale and affected area.
02-25-2015, 10:20 PM   #7
Wow, that was a horror movie. The thing was worthless by the end. I'll take your advice and not worry about it. I haven't used the lens yet but I will and hopefully it won't be a problem!
02-25-2015, 10:34 PM   #8
lol, at 4mins in, he's bandaged up.
02-25-2015, 10:44 PM   #9
QuoteOriginally posted by r0ckstarr Quote
I had noticed that too. I just can't figure out how he thought he knew enough to make an instructional video as he clearly was making it up as he went.
---------- Post added 02-25-15 at 10:51 PM ----------
QuoteOriginally posted by calsan Quote
...the dust will not stop any light and always be out of focus...
Is that true even if I use it with extension tubes which will reduce my focusing distance?
02-25-2015, 10:57 PM   #10
Stavri's Avatar
QuoteOriginally posted by Zephos Quote
I don't believe using tubes will impact your IQ, at most It might worsen the high ISO performance of the glass but that's negligible.
02-25-2015, 11:37 PM   #11
OMG, once I how bent the ring wasand how he had mangled it and the exposed metal was everywhere, I stopped watching. I wonder if this is how Pentax does it this way to clean out dust in lenses. :P As everyone has said, internal lens dust is a fact of life and not an issue with the pictures. Also, there is air there so you will see it come and go in time and you will notice that it will be there one day and gone the next if you are out and zooming.
It reminds me to a lesser extent of changing the VF screen in my K-X....I only had it less than a month and wanted to get a couple specs of dust. Next thing I know, I had the screen off, and blew it off when I had it, which worked I guess, and then I put it in, hit a it slightly on the metal frame and next thing I know, it was scratched. I had to order a new screen, put it on cautiously, and worked fine this time. Never touched it again, even if I see a speck here on and off in time.
Moral of the story, if it is not affecting your pictures, leave well enough alone, you can do much more damage than good.
02-26-2015, 08:10 AM   #12
Driline's Avatar
Precision camera?
02-26-2015, 09:16 AM   #13
Ha ha....well ? Einstien at work ! He did get rid of the dust ? Next week when he does it again the front ring will come off easier !
Leave it or Send it to Erik.....Bottom line.
02-26-2015, 12:37 PM   #14
OMG! I couldn't keep watching that.... just wanted to cry WHY?????
02-26-2015, 12:45 PM   #15
QuoteOriginally posted by mholford Quote
I told you it was a horror film. (Mind you the comic timing of the plaster, and the big reveal at the end, is simply genius).
I do hope he never makes any more videos though. I don't think I could sit through the human centilens.
dust, element, k-mount, pentax lens, photography, slr lens
Are prices getting way out of line... Raybo Pentax SLR Lens Discussion 8 02-26-2015 09:55 AM
Getting out of green mode Cath Pesudovs Visitors' Center 3 12-15-2013 11:32 AM
For Sale - Sold: Getting Out of Photography. Lots for sale cinaibur Sold Items 5 09-21-2009 04:56 PM
Getting the most out of my K20D shadowraven Pentax DSLR Discussion 19 01-29-2009 04:35 AM
Getting My Mind Out of P&S Thinking nonnstop Photographic Technique 15 04-22-2008 03:20 AM
All times are GMT -7. The time now is 06:54 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
