03-02-2015, 09:05 AM   #1
16-85mm F3.5-5.6 OR 2.8 SMC 16-50 ?
Quality difference between the newer HD Pentax-DA 16-85mm F3.5-5.6 ED DC WR and the SMC 16-50mm f/2.8 DA* ED AL IF SDM K-Mount AF ?
Any opinions on and between these two lenses ??
---------- Post added 03-02-15 at 09:49 AM ----------
Besides how fast both are , how much quality difference can one tell . The 16-50 is larger to handle and wider glass obvisouly . On the other hand , the 16-85 is more comfortable to work with and I've read a lot of discussion that give it high remarks . The SDM has been a big issue with the other but read that the newer ones have been corrected .
03-02-2015, 11:03 AM   #2
cali92rs's Avatar
QuoteOriginally posted by dudleyg Quote
I personally would go for the 16-85mm.
Any reports of the newer ones SDM being corrected is just forum hearsay because Pentax has not publicly announced a problem even exists in the first place. And besides, how could you be sure when the lens was built even if it were true?
03-02-2015, 11:19 AM   #3
Emperor and Senpai
VoiceOfReason's Avatar
What do you want to do with it? The 16-50 will likely be sharper and better for low light, both are WR, and the 16-85 has longer reach.
03-02-2015, 11:23 AM   #4
Thank you for you reply . Yes the SDM issue could be hersay, it just seems a Huge issue with that lens. Well I bought both and going to try both out , hopefuly sell one of them LOL , As far as the 16-85 goes , it seems like it's a bit if a step up from the 18-135 wr lens which a lot of people have said . So will see. thanks again . BH photo has it on sale now .
---------- Post added 03-02-15 at 11:26 AM ----------
You actually think the 16 - 50 would be sharper ? what do i want to do with it would be to use as my all around lens but with quality sans the bulkness of the larger one .
03-02-2015, 11:45 AM   #5
I've seen some good images from the 16-85, but an f/3.5-5.6 variable aperture really bugs me. The DA*16-50 gives nice images at f/3.5 or f/4. The 16-85 isn't going to be able to shoot 50mm at those apertures. Even worse, any such lenses I've used in the past don't allow you to keep the aperture stopped down by only 1/3 or 2/3 stops as you zoom in and out. So for near-optimal IQ (while maintaining a wider aperture - my typical shooting scenario) you have to constantly be monitoring and re-adjusting the aperture. This largely defeats the purpose of a zoom, which is for convenience and avoiding "missing the shot" - especially for events or other situations where you have to concentrate on composition and timing.
So in the end such a lens is going to drive my crazy. If I have time to carefully plan my shots I may as well use primes. The DA*16-50 allows me to maintain my spontaneity and doesn't require too much of a compromise in IQ (compared to primes).
---------- Post added 03-02-15 at 10:56 AM ----------
For me there's no perfect all-around lens. The DA*16-50 and DA*50-135 combo is my compromise - and one that I'm very happy with (especially the DA*50-135). If I really need both at the same time I carry two bodies. A zoom that covers most of that range by itself involves too much sacrifice in IQ or capability. I was rather happy with the FA 24-90/3.5-4.5, but I've found f/3.5-4.5 (or constant f/4, for that matter) much more workable than f/3.5-5.6. The only lens I really like that (barely) has more that 1-stop variable aperture is the FA28-105/3.2-4.5. But it already seems a bit slow at times. Constant f/2.8 (or sometimes f/4) is just better for me.
Nevertheless, if you don't shoot at such wide apertures much the 16-85 appears to have very nice IQ.
03-02-2015, 12:49 PM - 1 Like   #6
The big reason to choose the 16-50 is if you need the faster aperture. The problem I always have with variable aperture zooms is that they are fastest on the wide end, where it is least useful, while on the long end, where you could really use the faster aperture, you are stuck at f5.6.
My 16-50 lives at f4, except when I am shooting landscape, when I set it to f8.
03-02-2015, 02:09 PM   #7
Emperor and Senpai
I only see one big thing wrong with that picture. All that white stuff.
03-02-2015, 02:47 PM   #8
I like the way you operate
03-03-2015, 06:37 AM   #9
I like this
03-03-2015, 02:41 PM   #10
QuoteOriginally posted by VoiceOfReason Quote
Tell me about. And we're supposed to get 6 to 8 inches of sleet/snow tomorrow.
And it was 50 degrees today.
The joys of weather in southern Indiana.
03-03-2015, 03:15 PM   #11
LOL , I notice you live in southern Indiana , across from me on Eastern Parkway. Perhaps maybe it would be nice to hook up and do some photographic shooting , at least talk about it . what's you think ?
03-03-2015, 03:50 PM   #12
SpecialK's Avatar
The problem I always have with variable aperture zooms is that they are fastest on the wide end, where it is least useful...
You could also say fast at the wide end is useful indoors where you would normally have lower light. As always..."it depends".
03-04-2015, 09:42 AM   #13
Personally, I would think the expensive 16-50 would be used outdoors mostly and therfore would not really need the fast 2.8 aperture. I've been testing one that I bought on Ebay and find it quite slow to work with as the shutter does not fire right away a bit , tends to search for focal point, big and heavy and pictures do not seem to have fantastic sharpness for a "high end" lens and Manual operation works better. I just got the HD 16-85 lens today via BHphoto as it's on sale for 650 now, It seems to perform very fast shutter wise and pictures seem to come on sharp too . Seems like a very nice walk around lens compared to the 18-135 and the expensive 16-50. I will do some more testing and probably sell the High End 2.8 16-50mm Pentax lens. Let me know if anyone is interested.
03-04-2015, 12:18 PM   #14
Driline's Avatar
Without pictures it never happened.
16-85mm, 16-85mm f3.5-5.6, aperture, compromise, da*16-50, da*50-135, difference between ..., f3.5-5.6, images, iq, issue, k-mount, lens, pentax lens, primes, quality, sdm, sdm issue, slr lens, smc, time
Argument for the 16-85mm F3.5-5.6 rrstuff Pentax SLR Lens Discussion 47 11-25-2014 07:55 PM
HD Pentax-DA 16-85mm F3.5-5.6 ED DC WR: A Closer Look Adam Homepage & Official Pentax News 10 09-16-2014 08:22 AM
For Sale - Sold: Pentax K-5, K-7, Pentax 16-50 F2.8, Sigma 18-250 F3.5-6.3 OS terihanright Sold Items 12 12-19-2013 05:16 AM
For Sale - Sold: smc PENTAX-DA* 1:2.8 16-50 lens, just installed new SDM motor, 5.5 months warranty. grahame Sold Items 7 11-24-2013 10:25 AM
Sigma 8-16 f4.5-5.6 or Sigma 10-20 f3.5 Cucho Pentax SLR Lens Discussion 9 05-14-2013 12:31 PM
All times are GMT -7. The time now is 10:50 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
