Originally posted by Not a Number You got to remember too that a cropped sensor is only looking at essentially the center area of the full frame image circle. Measuring the edge and corner portions of a cropped image are not the same areas as the edge and corner of the full frame image.
^^^this
i just compared three 50's today on the a7r, the super tak 50/1.4 cleaned up quicker on the sides and corners than an md rokker-x 50/1.7 and a nikon 50/1.7.
it was also much nicer to use, with more aperture stops and better focusing action, that allowed for more degrees of rotation at the critical focus point... it actually had better center contrast wide open than the other two did, which is clearly visible with focus peaking... the focus point was the usual address numbers on the side of a building, probably a good 100 years away.
i think that lens battles are won on the sides first, then the corners... i haven't seen very many lenses that were unacceptable in the center, but a high pixel density sensor like the k3 has is going to be tougher on that than my a7r is.
