Originally posted by nonstopnick Thanks for all the replies. As for DOF: i could get the shot at 35mm with my current lens at f4, but am stopping the lens down a couple stops to gain some DOF which means I have to crank the ISO. The da35 should give me more DOF at the same f4. Correct?
If you keep the framing and shooting distance the same (same amount of puppies in the photo) on the same camera ONLY apperture will change the deph of field.
So using a DA35 f/2.4 or a 18-135 or a 17-50 f/2.8 or a sigma 35mm f/1.4... All will give the same deph of field at f/4 than your 18-135 is providing.
In photography, all is about light, so in all honestly you should consider the lighting of your scene instead of trying to buy new lenses.
Put the puppies outside in daylight and there will be lot of light to play with and you'd be able to shoot at f/8-f/11 while keeping low isos. Be aware of the light direction overall and your picture will look infinitely better than with the best lense in a crappy light environement.
If you can't go outside, you can at least ensure your interior has some great lighting, ensure you shoot on a sunny day, ensure your are in a room with lot of light and windows, add the artificial lighting at your disposal to add even more light, choose a part of the room where the lighting is the best and make your puppies look the best and take some shoots. You may have to crack the iso to something like 800-1600, but that should be quite do-able.
Usually I would say to use a flash. I know you don't want too but there are the laws of physics and all the pro shooting portraiture use flashes system for a reason. That's not going to cut it with the bundled flash, so you need to buy one. There one drawback throught. i would say not linked at all with your willingness to use a flash or not, but the effect a flash can have on your puppies. I know for human babies flash is forbidden, there a risk it damage their eyes, at least when there are only a few month old. Could be the same for your puppies, I would not take the risk.
So instead of spending money on a lense that will reduce your deph of field even more, I would just ensure there lot of light available when taking the shoots.
As for the lenses, well DA35 and DA50 are great to help keep iso low by using their wide apperture. You'll get some shallow deph of fied in particular if you shooting from short distance but the DA35 should be able to give some deph of field for a wider shoot. That may not be that great for your puppies but that can be great for other occasions even through in interiors one often need wide angle more like a 15 or 24mm. DA21 f/3.2 is great but not really better than your DA18-135 for gathering light through at the same focal length.
Leaning to post process well your pictures, setting the right noise removal settings, using raws and the right exposure from the begining can also get some nice results. From a streigth JPEG or basic post post processing, you can gain easily 1EV of light. Using flashes skillfully will not necessarily lower your isos that much but make the lighting far better and the photo look much better.
