Originally posted by nonstopnick I currently own a K50 and my only lens thus far is the DA 18-135 3.5-5.6 WR. I like the lens outside, but it needs lots of light, so i find myself with a wide open lens and no DOF. We are currently raising a litter of puppies and I am ending up with in focus eyes and blurry noses!
Let's start with this fact:
ROUGHLY Speaking, a given focal length at a given f/stop gives the same depth of field on the same sensor. This means that your DA 18-135 set at 35mm and shot at f/4 gives you the same DOF as the 35mm f/2.4 lens also shot at the same f/4. The 35mm would be able to produce LESS depth of field for those times that you want to do that.
Let's also agree that you may be experiencing bad focus - which lower light with slower lenses will have more trouble with than the 35mm f/2.4 would.
You may want to test your AF calibration to see if you are front or rear focused which will also impact your keeper ratio.
