Originally posted by foto guy
Hi foto guy.
Thanks for your recommendation. According to the reviews, that seems to be a very good lens. But after searching eBay, I found the price to be quite high for what I really need. I mean, the price may be perfectly ok, but I won't use this lens and camera as primary equipment. I already have a good DSLR with a good lens so I don't want to spend that much on a lens that I will use sporadically.
But anyway, thanks a lot for your recommendation. I will definetely take into account for future purchases.
Originally posted by Sagitta
FWIW, the F 35-70 is perhaps the sharpest, lightest and closest thing you'll get to a stack of primes in old, cheap Lensland. Period. You can buy it for lunch money. If you check out the PF Lens user reviews, its the highest rated F series zoom outside the ultra wides, and beats out quite a few F series primes in the process.
EDIT: It also has its macro mode, which is very handy to have for close focus stuff. You should be able to snag it for under $40 (probably under $30) with some careful hunting.
Wide open...
f/4.5
Yes, the 35-70 was what someone recommended before. But, since I will be using the SFX+Lens for family photos (vacation etc), street, landscapes and architecture, I won't use the 51-70 zoom range too much, and since I will use the Zenitar 50mm in this body (SFX) or in another, I will only use the range 35 - 49 from the lens you suggest, that is why I think that a prime lens could be a good choice too, although it will give me less flexibility.
But yes, the 35 - 70 is a lens I'm considering purchasing because of its balance price-quality, if I can find it at a lower price than a good prime lens.
Thanks you too for your answer.
Originally posted by hcc
Last year I was after a fast lens about 24-28 mm. After careful research, I went for the CZ 28mm f2.0 and I am very happy with the decision. The CZ28mm f2 is MF, metallic construction, very smooth focus ring and excellent IQ.
The problem is that there are few wide and fast lenses. And they are not cheap....
My 5 cents...
Yes, I know that lens, but way too expensive for being a "sporadic use" lens.
Originally posted by Mistlefoot
No 18-55 love?
You mean the kit lens that comes with today's DSLRs?
Originally posted by Kerrowdown
Sorry, I missed your answer.
I don't live in Scottland, but a certain region in a country that is not in the UK, south-west of EU, that has a similar weather that UK :P
Many people says this is a celtic country too. Even there is a football (soccer) team called Celta
