06-03-2008, 07:18 PM   #1
M42 Lens Question
ON the m42 pentax lenses their is a slide switch for auto or manual. Which do you set it to when using on a pentax adaptor on a digital camera thanks .....
06-03-2008, 07:47 PM   #2
KungPOW's Avatar
Use it to stop the lens down before you take a photo.
The K mount does not has the mechanism to automatically stop the lens down when the photo is taken.
06-03-2008, 07:56 PM   #3
maxwell1295's Avatar
It should be set to Manual.
06-03-2008, 09:26 PM   #4
ryan s's Avatar
QuoteOriginally posted by maxwell1295 Quote
+1 for manual...
06-03-2008, 10:56 PM   #5
Big Dave's Avatar
If you don't set it to manual, the lens will remain wide open, regardless of the f-stop setting.
Dave
06-03-2008, 11:05 PM   #6
pentagor's Avatar
I set it to manual and use Av setting on the body. The focusing is somehow tough at small apertures, but it does work.
I'm not used to stole the topic, but the focus confirmation does not work with M42 lenses. Is this normal?
06-03-2008, 11:47 PM   #7
frank's Avatar
You can set it to auto for focusing (the lens is wide open now, easier to focus), then move it to manual to take the shot (at your setting aperture). This works the best for small apertures and w/ a tripod
06-03-2008, 11:51 PM   #8
frank's Avatar
QuoteOriginally posted by pentagor Quote
As I said above, you can set it to auto to focus first, then shift to manual to take the shot.
The focus confirmation should work w/ the original M42 to K adapter, as long as you got enough light (aperture is big enough).
06-04-2008, 01:19 AM   #9
Frank ... I never thought of doing that .... I notice the VF go dark ... and focus confirmation was hard to get ... plus me squinting at the same time ... hee hee.
I might try that next time.
06-04-2008, 01:39 AM   #10
You got a k100d, I think there is a setting in the menus for focus confirmation to work. "something screwmount something". On the K10D it works out of the box. You on the other hand have Focus trapping on m42 out of the box, K10D don't unless its wide enough to short the contacts. Which is annoying.
06-04-2008, 01:45 AM   #11
pentagor's Avatar
QuoteOriginally posted by Zewrak Quote
Sorry for a dumb question: what is focus trapping?
06-04-2008, 02:00 AM   #12
When you hold the shutter release pressed down fully and then focus. When something gains focus the shot is taken. It wont take a shot until your in focus. You need to have the camera set in Autofocus mode though.
It's great for flying birds etc just keep the button pressed down and everytime you get focus in on that bird, a shot is taken (given that you have rapid fire set).
Also very useful when you have long teles.
06-04-2008, 02:02 AM   #13
Transit's Avatar
There are no dumb questions
Trap focus is when you stick the camera on autofocus (switch on front left of cam)
with a manual focus lens. Depress shutter release fully then slowly focus lens.
The shot will be taken when the camera is happy with focus
The cam will only release the shutter when it thinks focus is achieved.
I'm sure someone else can explain it better
cheers
Pete
06-04-2008, 02:06 AM   #14
pentagor's Avatar
Oh, thanks. I know the functionality, but I didn't know what it is called.
06-04-2008, 02:41 AM   #15
Arjay Bee's Avatar
Some M42 lenses prior to A/M switch incorporation have a very small lens barrel and the pin that actuates the aperture does not strike against any object on the dslr body. In order to close down the aperture to the ring value the pin needs to be held in somehow. I used a nylon tube drilled out to act as a sleeve, removed the back plate of the lens and cut the sleeve to sit between the plate and the heel of the pin. Problem solved and easily reversed.
There is now a constant tension on the aperture return springs - somust remember to store the lens at the widest aperture.
k-mount, m42, m42 lens, pentax, pentax lens, slr lens
Question about exposure with M42 lens. hahifuheho Pentax SLR Lens Discussion 13 08-16-2009 01:36 AM
m42 lens question gokenin Pentax SLR Lens Discussion 11 03-20-2009 03:59 PM
Question on Pentax M42 lens my_photography Troubleshooting and Beginner Help 1 02-25-2009 04:10 AM
K10D+M42 lens+SigmaEF530 FP question nicholashan Pentax DSLR Discussion 2 06-25-2008 05:04 PM
Question About Using an M42 Lens with a ZX-M Body zx-m Pentax SLR Lens Discussion 6 06-05-2008 03:38 AM
All times are GMT -7. The time now is 03:53 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
