From the looks of it, the fungus is very superficial. The fungus may look terminal, but I'm sure it did not eat into the glass yet. The haze looking layer is probably just moisture buildup. It's harmless to the glass. I've dealt with worse. The rear-most element can be easily removed. A wash and wipe is all it needs.
The front elements will pop out when you unscrew the retaining clip. There are there elements in the front group. In my case, it was not very tight and I managed to unscrew with just my fingernails. The rear element can be unscrewed by hand if I'm not mistaken. If I remember correctly, there are a total of seven elements in this lens. This is quite an easy lens to disassemble and reassemble.
Speaking from my own experience, the F 35-70 has a joined element somewhere in the center. If there is fungus growth is in between the binding compound of the joined element, then the lens is unusable. It will ghost at the slightest of direct lighting. If that's the case, list lens up on ebay as "parts or not working" with a description of "sold-as-is-i-don't-know-a-damn-thing-about-it"
Someone might want the lens for the little aperture click bearing
