Originally posted by Nicolas06 Lens Rental explain they have much more issues with Samyang than with other lenses and that they can't keep them as long as other brands.
The "Lensrentals Repair Data: 2012-2013" appeared to have been modified by LensRentals because they had some classification issue with Rokinon/Bower/Samyang lenses and hence removed the data. Perhaps that's why you cannot find it anymore.
I don't know whether the data was pulled because it was misleading due to the classification issue. I do know that I don't see people complaining about problems with Samyang lenses. I also know that while Roger Cicala (from LensRentals) observed the use of some plastic parts and was sceptical about the longevity of a particular model he looked at (Rokinon 14mm f/2.8), he also called it a "bargain" and noted that replacing it with a new copy would be cheaper than having a Nikon 14-24 f/2.8 repaired. He also called the lens better than the Nikon 14/2.8.
He also notes that if someone babies their lens, it could easily last a lifetime while the LensRentals copies see a lot of stress.
I remain unconvinced that there is actually a real cause for concern.
