04-06-2015, 01:44 PM   #1
c.a.m's Avatar
DA 35mm Limited - Shifting viewfinder image in Manual Focus
Hi,
When I focus manually with my DA 35mm Limited, the image ‘jumps’ or shifts visibly in the viewfinder or in the Liveview display, as I rack the focus ring back and forth to achieve focus. It’s especially noticeable at close subject distances or when using the magnified Liveview.
While I can achieve the proper focus, the exercise is tedious. There are no apparent issues with autofocus. I’m using a K-5 II, mounted on a sturdy tripod and robust ball head. My other lenses work fine in MF.
The inner barrel exhibits a slight wobble when I wiggle it by hand.
The lens has exhibited this issue since I got it several years ago. Soon after I got the lens, I sent it for warranty service to Pentax Canada; they ‘adjusted’ it but the problem persists.
I suspect the likely cause is a slight play in the focus helicoid. The problem seems to be getting worse (or my patience is wearing thin).
Has anyone experienced a similar behaviour with MF with this lens or other DA Limiteds?
Thanks
- Craig
04-06-2015, 03:18 PM   #2
waterfall's Avatar
In macro closeup with the 35, final focus is tuned by moving the lens barrel closer to or farther from the subject. How close was your subject?
04-06-2015, 06:54 PM   #3
QuoteOriginally posted by c.a.m Quote
Hi,
Thanks
- Craig
I had the 35 limited for about 3 years and manual focused all the time for macro images. I never noticed the behavior you described. I had the other limiteds as well but didn't manual focus much with them. Forgot to mention i have a k-5 and rarely used the liveview.
04-07-2015, 10:05 AM   #4
narual's Avatar
You might want to try using a macro rail to focus if you're doing up-close work. Won't hurt. Might help. Don't have the lens in question so I can't comment on the problem directly, but if it doesn't go away a rail might help.
04-07-2015, 06:22 PM   #5
c.a.m's Avatar
Thanks for the suggestions, folks. I've thought of getting a focus rail, which would aid macro work in several ways. Dice, thanks for mentioning your experience with your copy.
Otherwise, my 35 Ltd works well, and it's spot on when auto-focused.
- Craig
35mm, da, da 35mm, focus, image, k-mount, lens, liveview, mf, pentax lens, slr lens, viewfinder, viewfinder image
Viewfinder ( focus screen) options for manual lenses Dlanor Sekao Pentax K-30 & K-50 6 12-01-2014 11:58 AM
Slide Duplication: Image is tack sharp in viewfinder but captured image is not. MD Optofonik Film Processing, Scanning, and Darkroom 15 05-12-2014 05:18 PM
For Sale - Sold: DA Limited 21mm / DA Limited 35mm Macro / DA Limited 70mm top-quark Sold Items 3 04-23-2013 05:01 AM
K-x front-focus with DA 35mm F2.4 AL and other manual lenses 7samurai Pentax DSLR Discussion 18 03-20-2012 06:45 PM
istDL split image focus viewfinder? speedfoos Pentax Camera and Field Accessories 4 08-13-2011 06:18 AM
All times are GMT -7. The time now is 11:21 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
