06-05-2008, 02:34 PM   #1
Pentax SMC M 50 f/1.7
From what I have read it seems that in AV mode, despite the green button function, a correct exposure might not be achieved.
My question is that if this also happens in M mode or is it more accurate?
I also read in the manual that, contrary to the AV mode, an exposure check is possible in M mode. Can you explain what is this achieved?
Thank you
06-05-2008, 02:59 PM   #2
Well since the lens will be wideopen while you meter with the green button and closed down to whatever aperture your using when you take the picture, the metering will be off.
06-05-2008, 03:38 PM   #3
pschlute's Avatar
QuoteOriginally posted by coloseu Quote
Thank you
In Av mode correct exposure will be achieved .....but always using the widest aperture. The camera will select the correct shutter speed. The limitation of Av mode with "K" and M lenses is that it makes no difference what you set the aperture to the camera will meter and capture wide open.
In manual mode it is different.. you press the green button to stop-down the lens and take a meter reading. The camera will them capture using the aperture you select and the shutter speed it selects basis the meter reading.
av, exposure, k-mount, mode, pentax lens, pentax smc, slr lens
For Sale - Sold: SMC Pentax-F 35-70mm F3.5-4.5;SMC Pentax-A 50mm F2;SMC Pentax-DA L 18-55mm F3. TATA Sold Items 14 06-17-2010 04:05 PM
For Sale - Sold: FS: Pentax SMC Pentax-A 50mm 1:1.7 and SMC Pentax-A 70-210mm F4 Zoom davef Sold Items 6 01-19-2008 07:16 PM
All times are GMT -7. The time now is 09:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
