Hi,
I have the same problem on a black-anodized flange on an old Porst 55mm f1.2 mounted on a k-70 body, with firmware version 1.11
Using "M" mode, with the camera set to allow the use of the aperture ring, fixed ISO setting: the green button works intermittently, probably due to a not good contact.
I scratched the flange in correspondence of where the digital communication contact is (exactly opposite to the red dot). This was sufficient to let the camera aknowledge that a lens is attached.
Now the green button correctly stops-down the iris when it should.
Thanks for the thread, it helped me a lot.
Leodp
