Originally posted by Besta Thanks all, I have booked the tours for both upper and lower antelope canyon. Unfortunately, it has to be a regular tour not the photographic tours for our family.
Here is my 26-day itinerary: I will fry from
1) BKK --> Osaka (for a day) --> LAX (half day) --> DFW then
2) DFW --> LAS --> OKC then
3) OKC --> BZN and RAP --> DFW then
4) TUL--> ORD (for a day) --> HKG --> BKK
I will take 50-135, and 300+1.4TC and GoPro with me. The other two or three lens will be selected from either 15, 21, 31, 40, or 12-24 and either tripod or monopod. Up to this point, still not so sure either whether to carry the set of filters with me, might not have time to spend longer times at each location and set up all equipment for particular shots.
Will drop a line or two after I get back from the trip. Hopefully the weather will be good for the whole trip. ^__^
This is not too bad. I did Zion, Bryce, and the Grand Canyon (North and south rims) in 2005. Took my *istD and PZ1 plus 18-35, 28-105, 70-200/2.8 and 1.4xTC in an attempt to travel light. Also took AF500FTZ. In hind sight I should have also taken my 300/4 and 1.7x AF Converter because for wild life 500mm on a crop sensor is a big plus.. I used the PZ1 exclusively with the 18-35 which in today's crop sensor world is equal to a 12mm AND there were times I wish I had wider
For wildlife I found the north rim better than the south rim, except that they had condors at the south rim. Bit bird, 3 meter wing span, but still a 70-200 with a 1.4 TC wa not enough. Wild life also needs a flash if shooting in the woods. It can be pretty dark under the tree cover
