Originally posted by tingeltangelben Maybe it's because I'm an absolute beginner, but it seems to be a nice lens. It goes down to f 1.7 and picture quality is far superior to my other lenses. Am I wrong and all my other lenses just a bit rubbish?
It actually is a great lens. Most primes (fixed focal length) lenses from that era are quite good. A lot of people on this forum use a wide variety of older lenses, even third party and adapted lenses.
Im glad you are using it right and getting good results! I assume you already enabled aperture ring in the Menu and are happily using M mode with green button to meter. ISO has to be constant, as auto-ISO or any mode other than M will default to Av, which has constant automatic metering, but it only shoots wide open f(f1.7).
One other tip is to use the feature Catch in Focus, which gives you a type of AF even with manual lenses. You enable it, turn on AF, and then hold the shutter button. The shutter won't actually go off until something comes in focus. This is meant to be used to wait for people or animals to enter the frame, but it can be used as a focus aid, because you can simply twist the focus ring while holding the shutter, and the exposure will be taken once something comes in focus. Only works with centre point.
Regarding which affordable modern lenses can compete with that M 50mm.. well, most of the primes. DA 35mm f2.4 is a nice one and slightly wider angle, and with full automation. The DA 50mm f1.8 is the same basic optical design as your lens, but with modern lens coatings, rounded aperture blades, but mostly made of plastic and with no DoF markers or aperture ring. But the kit lenses, DA L lenses, or ultra zooms and budget zooms will not be able to compete with that M 50mm.
Im surprised that Vivitar 28mm doesn't work out well for you. Adding a lens hood might help it a lot (lens hoods help older lenses because those have older, simpler lens coatings). Of course, keep in mind that wide angle won't catch as much detail as telephoto, because it is.. well, wide. You have to focus near the minimum distance, get really close to the subject, if you want the wide angle to show its sharpness.
