Originally posted by Bahman1358 Thank you every one
I want to visit Istanbul, Moscow and Kazan. Sightseeing and visiting museum will be main activity in the travel. I won't go in forest for finding birds and wild animals.
Do you think I need 200 mm or more focal length in cities?
I red a lot of bad things about auto focus system of 50-135 mm lens. Have it really solved?
I have 105mm macro lens so buying 135mm prime lens is not helpful.
Bahman, I think it is quite a difficult decision to chose between the 50-135 and the 200. I use both, and have no complaints for both IQ-wise.
Talking about the focal length, though, I've found the 200 does give valuable extra reach; it's something that's actually discernible in real world use, and valuable, especially for sightseeing where it's hard to predict what you'll encounter, and things may sometimes be quite far away to photograph.
On the other hand, with the 200 you'll lose the zoom convenience of the 50-135. So there'll inevitably be some lens switching with your 105mm, which can be bothersome. In using the 200, there'll also be some "zooming with the feet". This means you'll need to walk around a bit, to compose your shots, since the lens can't zoom. It's just a different approach to photography, but you should take note of this. In particular, are you traveling alone, on your own leisurely time schedule, or will you be with a tour group? If the latter, then the "zooming with the feet" may not always be practical/possible.
Talking again about that extra reach, and in particular inside dim museums. If you chose the 50-135, and the 135mm setting proves to be insufficiently long for certain shots you want to take, then the only choice will be to crop. Now since these are telephoto lenses, the shutter speeds will have to be rather high (I'm assuming hand-held operation). This, plus the low-light conditions, will bump up the ISO. If after that you still need to crop, this can make the noise more prominent, even with a modern sensor like the K-3's. Of course, one can de-noise in PP, but you understand what I mean... So, it's something to take into consideration.
---------- Post added 04-28-15 at 01:18 AM ----------
Originally posted by r0ckstarr For someone looking for a 200*, such as myself, does anyone who suggested the *50-135 have both? If so, in terms of image quality, which do you like better? Can you post photos from each lens to show?
Sent you PM concerning your query above.
