Originally posted by KatPal Yep, it seems all too confusing...could not they make it simpler and release only one :-)
It says
M in the description that you posted earlier. Not sure what is confusing about that
Two quotes from another thread (from 2010)
Originally posted by wallyb In layman's terms:
M42: first kinds of lenses Pentax produced, for old screwmount bodies such as the Spotmatic; they can be adapted to all K-mount cameras
K: first bayonet series, no actual "K" markings
M: second bayonet series, some say the "M" marking stands for "mini" as most comparable lenses are smaller than their K counterparts
A: in general, K- or M-series lenses updated with auto-aperture contacts, and sometimes worse build quality
F: first foray into AF lenses
FA: second foray, mostly just physical re-designs of F lenses, but also some new ones (I think)
DA: third line of AF lenses, usually deigned for APS-C sized sensors only (but NOT always)
*: higher build or optics quality for older lenses (before Limiteds were introduced)
Ltd.: Limited lens, arguably the highest-build-quality among lenses Pentax has made, very compact lenses for their focal length, and highly superior image quality to comparable lenses
Originally posted by Lowell Goudge the real difference between K and M is that the M series attempted to retain most lenses with a 49mm filter, and be very compact. The idea was to keep 49mm filters as a standard to help the photographer in reducing the number of filters. WHile this did not impact some lenses, others disappeared or changed.
in the M series, there was no 50mm F1.2, the 85mm went from F1.8 to F2, the 135mm F2.5 was dropped, the 200mm F2.5 I think got dropped and only a 200mm F4.
Additionally I think many of the wide angle lenses went to F3.5 as opposed to F2 or F2.8, but I am not really sure.
There were some improvements, however, specifically in the 300F4 which was downsized a little, and the 400F5.6 which became auto aperture as opposed to preset.
While some people consider the K mounts as re-packaged SMC Taks some were much better optically.
