Originally posted by GlennG In one instance I compared similar images at 40 mm length from the 17-70 and my DA 40, and the 17-70 was very close to the 40, and by "very close" I mean "VERY CLOSE".
I was viewing some images of redwoods shot in foggy conditions under the assumption that they were taken with the DA 15, marveling at how impressive that lens is. Then I checked the exif data and noted that the images were taken by the DA 17-70! So yes, sometimes, given what sort of light you're throwing at it, the DA 17-70 can come very close to holding it's own with a limited. Where the limited has a definite edge is consistency of output. In subdued light photographing objects with a lot of green in them, the DA 17-70 is nearly on par with the DA 15. But in bright light photographing objects with a lot of blue in them, the DA 15 will reassert its supremacy.
However, despite the fine optical quality of the DA 17-70, I nevertheless do plan at some point to upgrade to the DA 16-85. While the differences in terms of image quality may be very minor, the DA 16-85 does seem to address a number of weaknesses afflicting the 17-70. While none of these weaknesses, when taken by itself, may amount to all that much, when added up, they provide at least enough of a reason for me to contemplate the upgrade. These weaknesses are:
1.
AF unreliability. My 17-70 front focuses at the wide end, back focuses in the middle, and is all over the place at the long end. It would be nice to have a standard zoom with reliable AF.
2.
WR and dust resistance. I have no WR lenses under 100mm. Having a WR standard zoom would definitely be a plus.
3.
HD coatings. The 17-70 contains a lot of glass and it is just a bit prone to veiling flare under strong light. Any improved resistance to flare, however minor, would be appreciated.
4.
Greater focal range. While I would never upgrade solely for the slight increase in focal range, having a lens that goes from 16mm to 85mm without serious compromises in optical quality would be rather handy. I'm not always thrilled with what my DA 17-70 does in the 60 to 70mm range, and often avoid shooting in that range. So getting the little extra range at the wide end and the 60 to 85 range at the long end is a nice little bonus.
Precisely because the DA 17-70 is a very nice lens, I'm in no hurry to upgrade. But by the end of the year, I do plan to get the DA 16-85.
