Originally posted by pentaxk3user I thought the dof would stay the same and the only difference between the full frame and the smaller sensor was the size it captured
You got it right. This is correct. Look at the attached image. It consists of two images, the one with the red border and the one with the yellow border.
The image with the red border is taken with an old Konica-Minolta Dimage A2 which has a pretty small sensor (8.5 mm x 6.6 mm). It has a zoom lens, and I have adjusted it to as near 35 mm as I could (now, that is 35 real millimeters, no crop quasi focal millimeters).
The image with the yellow border is taken with at Pentax K3 with at 35 mm lens (still real millimeters, and sensor size is 23.5 mm x 15.6 mm).
Both images are taken from the same standpoint and with the same aperture (f/4.0).
So: same distance, same focal length and same aperture, but different sensor size.
Since the Dimage A2 has a much smaller sensor than the K3, it will cover a proportionally smaller part of the K3,s image. If the K3 sensor had been just as large as the A2's sensor it would have taken the green bordered image. But since the sensor was not that small it took the yellow bordered image.
Now, the crop factor between those two sensors are huge: 2.67! How has this affected the DOF? See for yourself.
