Originally posted by derekkite Telephoto wildlife shooting consists of being on the edge of the capability of both the body and the lens, and marginal improvements in either make a difference whether a shot is passable or excellent. I suspect that the full frame or aps-c may be dependent to a large degree on the actual shooting circumstances of the individual. Some situations would give the advantage to one, another to the other. Ultimately if you can get close enough so that the subject almost fills the frame, then a full frame would be advantageous, giving a little more leeway in shutter speed with the lower noise. But that same advantage can be gained being a bit further away with an aps-c at the cost of a little worst noise.
I know that I crop substantially, and the higher resolution of aps-c is an advantage.
I was just looking at the different camera sensor stats for the K5IIS (which I have), the K3II (new stats) and the mention of a stat for the FF in its announcement. The spec for the K5IIS states it is a 16.3 MP sensor, the K3II stats mention a 24.35 sensor, and the mention of a 36-megapixels sensor for the full frame in an announcement which says "If we had to guess, we'd say 36-megapixels and a slightly bigger body than the K-3 to facilitate a larger grip." My K5IIS gets excellent pictures as it is and even if it gets old, it will probably be one of the best ever made. The K3II facilitates technology with its sensor mp, and probably has faster AF than its predecessors. If the Pentax FF has the 36 mp sensor and of course a reliable AF system, then it will be croppable and still give the FOV that has been mentioned. So, I am almost positive some of you may be possibly more experienced than me, but it is almost like the K3II is offering a great alternative in the APS-C line without really losing too much capability to the Full Frame if you are planning on doing wildlife zooming which may involve cropping, and the Pentax FF will offer almost the best of both worlds if it in fact does house a 36 mp sensor which will be croppable and still have the Full Frame capability for those that are interested in that type of FOV. The K3II, the Pentax FF, or the next APSC in line after the K3II will probably all be able to handle quite a bit in a nice way per the sensor mp if it is used technologically well. I know getting down to the real shooting preferences and needs of each specific user will make a difference in the final choice, but they really do seem like they will most likely be fulfilling products in their time just as my K5IIS has been. So, I really like the new Pentax choices. Per the information I have gained on this forum, I know what to look for in a more knowledgeable way.
