Originally posted by Oakland Rob How do the different Samyang/Rokinon/Bower 14mm's compare? different prices although I understand they are just rebranded.
I think they are optically all the same. Most are even the same in the appearance. Vivitar versions sometimes have a different focusing ring and stuff, but the same glass. Samyang makes them, but they get sold as Walimex, ProOptic, Falcon, Rokinon, Bower, Vivitar, and possibly others. This depends on your location, for example Walimex is in Germany, but I think it is difficult to find outside EU. And yes, sometimes the same store has a certain lens in two of these brands at different prices. Just get the cheaper one, as far as we know, they are all the same. The only Samyang you should avoid are the big tele lenses (500mm, 800mm, mirror lenses) and older lenses (Samyang has been around for a while, only in the past few years have they made such great glass). If you buy Samyang, make sure it is "for Pentax" because they make lenses for a variety of mounts, and others won't fit your camera.
When you said "older".. there is actually an older version of the 14mm, with slightly different characteristics, but you should only worry about that if you buy used. Or if you meant legacy older lenses that you might find, you won't have much luck with UWA. In the past, 24mm was really wide, and 20mm was extreme! On APSC, 20mm is that that wide. And often the quality of those old lenses is not as good as modern UWA, because UWA is complex and modern computer technology and robotic machines help out a lot. And lens coatings with flare. So old UWA lenses will either be expensive or not that good, at least ones wider than 20mm. This is why Samyang is usually the best, most affordable choice. Sigma makes 10-20mm zoom and Tamron makes 12-24mm, which are also good for UWA beginners, because they have a comfortable range and don't cost an arm and a leg. I've seen some great photos taken with these, but I don't think they are as contrasty and sharp as Samyang. But they do have AF!
Sorry I can't talk you out of it
But you know your needs. For just panorama, you might enjoy stitching, and you can get away with DA 50mm f1.8 (or even Pentax M 50mm f1.7 for $60. Its sharp enough, add a tight hood and its really top notch). Thing is, I rather enjoy my Samyang 14mm, even though I had to replace it once and the second copy is still a little decentered. I have a lens profile for it, but I don't use it very often. Distortion can often be handled even as you take shots, if you angle the camera right
