So, now my new HD DA70 has arrived, I'd like to fit a multi-coated UV filter / lens protector. I know many of you dislike the practice, but I'm in the habit of installing decent UV filters on my lenses to protect them, and to facilitate quick cleaning of the front element when I'm out and about.
With that said, does anyone know if using the original hood with a filter on the lens is likely to cause vignetting? I'm guessing the hood dimensions were worked out based on it being fitted directly to the lens. I know I can get rid of the vignetting in LR, but just wondered if anyone had real-world experience they could impart.
Thanks in advance
