Originally posted by condor27596 I meant focal length. I'm bad with the terms. But the directions shows a menu.
As noted this will only show if you have SR turned on and will only show until you hit a button (any button). And SR can be turned off by the camera automatically if you are in some shooting modes such as remote, timer and maybe some others. So if you are in the remote mode for example you will not get asked the focal length question.
You can however set the focal length in the menu manually if you want.
Note that this entry of focal length is only used by the SR system to determine the proper SR amounts. However, it has the added benefit (very important for manual lens users) of posting that focal length in the EXIF information so you can often determine what manual lens was used by checking the focal length in the EXIF.
