Thanks for the compliment ivoire. The eagle shot came out pretty well. Don't live in an area where they let you get close. That tree was out in the lake about 1000-1200 ft away. Didn't do much PP since I wanted to show what the lens could do. In full res shoot you can see the fish the eagle is eating. PP would add a little contrast, sharpen just the eagle some, and take the orangish color down a little (it was near sunset).
You certainly reduced the twitchiness. Must have a strong tripod to handle that much weight. Weight does aid stability. Being in the wind doesn't help any either.
Moon shot looks good. Shoot lots and pick the sharpest. Atmosphere can change that quickly. Astronomy people shoot hundreds of shots, pick the best. For planets they shoot web cams! Stack the best shots and actually give some observatories a run for the money. Considering trying this with the Burst mode on K20D.
Hope you get your wireless remote working again. Maybe battery died? Remote can be disassemled for battery replacement. Couldn't live without the wireless and K10/20D rear sensor. The Olympus only has wireless from front. Hard to get that to work between C5 and body. Have to hold everything just right. Oly doesn't have wired remote(
Yes, thats the right Pentax magnifier. It helps with any lens. Makes viewfinder 20% bigger. If you wear glasses it may make bottom info tougher to see. Thats better than out of focus pics.
Glad you are having fun with the big lens. Lots of work but it can be so impressive when it all clicks! Provides shots you can't get any other way. Have you tried a teleconverter yet. So far I find that the light loss is tough to deal with (even with Kenko 1.5). for wildlife may not be worth it. With K20D just crop some instead. For moon it can work with converter. You can also get a different attachment for C5 to put eyepiece in line with camera body. Holy magnification. They use this for planets.
Hope the learning curve has been shortened a little.
thanks
barondla
Check out POINT & SHOOT CONTEST 7 winners in P&S forum. Enter #8. Any type camera except slr. Any brand. Any subject.
